Author Topic: The middle distance between the two Plines  (Read 3772 times)
HOSNEYALAA
« on: December 03, 2018, 05:26:22 AM »
If possible, calculate the average distance between two Plines
As the attached picture
Crank
didier
  • expatrié
Re: The middle distance between the two Plines
« Reply #2 on: December 04, 2018, 02:12:21 AM »
Coucou
is this the average distance of all vertices between polylines ?
or is it the distance from the middle of the first polyline to the second ?
amicalement
eternal beginner ...
my english is not fluent ...
HOSNEYALAA
« Reply #3 on: December 04, 2018, 03:07:29 PM »
HI didier
HOSNEYALAA
« Reply #4 on: December 04, 2018, 03:44:39 PM »
The Green Line is not straight
It is taller than the blue line
As is attached
Is it possible to calculate the area space between the two lines?
And divide the value of the area ON  the ((horizontal)) length of the short blue line
HOSNEYALAA
« Reply #5 on: December 04, 2018, 03:53:38 PM »
Thank you Crank
I want a medium distance if possible
Crank
« Reply #6 on: December 05, 2018, 01:50:53 AM »
Now I'm not sure what you want:
- the average distance
- the distance between the midpoints of the polylines
HOSNEYALAA
« Reply #7 on: December 05, 2018, 05:20:26 AM »
hi Crank ,
I want
Thank you
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #9 on: December 05, 2018, 01:26:35 PM »
HOSNEYALAA
I am confused.
The drawing is different to the picture you posted.
I assume you want the distance from the middle of one Pline to the middle of another Pline.
The measured distance need not be perpendicular to either Pline.
Is that correct ??
Have you attempted to write any code yourself ? ...
or do you want someone to write the code for you ?
Called Kerry in my other life
I live at UTC + 13.00
HOSNEYALAA
« Reply #10 on: December 05, 2018, 01:52:41 PM »
Thank you kdub
The average distance between the two lines was required
The solution has been solved
https://www.cadtutor.net/forum/topic/66462-the-middle-distance-between-the-two-plines/
HOSNEYALAA
« Reply #11 on: December 05, 2018, 01:55:36 PM »
I'm sorry that my English is not good
I am currently learning writing a codes
HOSNEYALAA
« Reply #12 on: December 08, 2018, 06:30:32 AM »
GOOD
