Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Fast algorithm for finding 3D face boundary?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fast algorithm for finding 3D face boundary? (Read 2553 times)
well20152016
Newt
on:
December 03, 2018, 03:12:31 AM »
Logged
David Bethel
Swamp Rat
WWW
Re: Fast algorithm for finding 3D face boundary?
Reply #1 on:
December 03, 2018, 05:50:42 AM »
Isn't a 3DFACE is a boundary in most instances
Logged
R12 Dos - A2K
ribarm
Gator
Marko Ribar, architect
WWW
Reply #2 on:
December 03, 2018, 10:02:34 AM »
Hi this is improved version that accepts holes in 3dfaces network and manages to do breaking along boundary - 3DPOLYLINE if user want that... But nevertheless its slow - on my PC it took 920 secsonds for your cca 2500 3dfaces...
Code - Auto/Visual Lisp:
[Select]
defun
c:3dpolysaround3dfaces
vl
position
fuzz car
vl
member
if
unique uniquepl osm pdm pds ss ti i 3df pl pll plll el ell elll k z p1 p2 3dppl ch pp ppl pos1 pos2 ppp 3dppls p
;; (vl-position-fuzz 3.29 '(1.1 2.2 3.3 4.4 5.5 6.6 7.7 8.8 9.9) 0.01) => 2 ;;
defun
vl
position
fuzz
e l fuzz
car
vl
member
if
defun
car
vl
member
if
f l
ff r
setq
ff '
lambda
x
if
apply
f
list
x
setq
r x
vl-some
ff l
r
vl-position
car
vl
member
if
lambda
x
equal
e x fuzz
l
l
defun
car
vl
member
if
f l
ff r
setq
ff '
lambda
x
if
apply
f
list
x
setq
r x
vl-some
ff l
r
defun
unique
l
if
l
cons
car
l
unique
vl
remove
if
lambda
x
and
vl-some
lambda
y
equal
y
car
car
l
1e
6
x
vl-some
lambda
y
equal
y
cadr
car
l
1e
6
x
vl-some
lambda
y
equal
y
caddr
car
l
1e
6
x
vl-some
lambda
y
equal
y
cadddr
car
l
1e
6
x
l
defun
uniquepl
l
if
l
cons
car
l
uniquepl
vl
remove
if
lambda
x
equal
x
car
l
1e
6
l
setq
osm
getvar
'osmode
setq
pdm
getvar
'pdmode
setq
pds
getvar
'pdsize
setvar
'pdmode
35
setvar
'pdsize
1.5
prompt
\n
Select 3DFACE entities to process..."
setq
ss
ssget
0
"3DFACE"
if
ss
progn
setq
ti
car
_vl-times
repeat
setq
i
sslength
ss
setq
3df
ssname
ss
setq
i
1-
i
setq
pl
mapcar
cdr
vl
remove
if
not
lambda
x
vl-position
car
x
10
11
12
13
entget
3df
setq
pll
cons
pl pll
setq
plll
vl
remove
if
lambda
x
length
uniquepl x
2
pll
setq
plll
unique plll
foreach
pl plll
setq
el
mapcar
lambda
a b
list
a b
pl
cdr
reverse
cons
car
pl
reverse
pl
setq
ell
append
el ell
setq
ell
vl
remove
if
lambda
x
equal
apply
distance
x
0.0
1e
6
ell
setq
k
1
elll ell
foreach
e1 ell
setq
k
1+
k
z
nil
foreach
e2
vl-remove
nil
mapcar
lambda
x
if
null
z
setq
z
0
setq
z
1+
z
if
k z
x
ell
if
or
equal
e1 e2 1e
6
equal
e1
reverse
e2
1e
6
setq
elll
vl-remove
e1 elll
while
elll
setq
el
car
elll
setq
p1
car
el
p2
cadr
el
setq
3dppl
cons
p1 3dppl
setq
elll
cdr
elll
while
setq
el
car
vl
member
if
lambda
x
or
equal
p2
car
x
1e
6
equal
p2
cadr
x
1e
6
elll
if
equal
car
el
p2 1e
6
setq
p1
car
el
p2
cadr
el
setq
p1
cadr
el
p2
car
el
setq
elll
vl-remove
el elll
setq
3dppl
cons
p1 3dppl
prompt
\n
PRESS ANY KEY TO CONTINUE..."
vl
catch
all
apply
grread
foreach
p 3dppl
setq
pp
entmakex
list
0
"POINT"
cons
10
p
redraw
pp
3
vl-cmdf
"_.DELAY"
100
entdel
pp
initget
"Yes No"
setq
ch
getkword
\n
Pick breaking points in shown direction or draw closed 3DPOLYLINE [Yes/No] <Yes> : "
if
null
ch
setq
ch
"Yes"
if
ch
"Yes"
progn
setvar
'osmode
1
while
setq
pp
getpoint
\n
Pick or specify breaking point - ENTER TO FINISH (at least 2 points on contour must be specified in shown direction) : "
setq
ppl
cons
pp ppl
setq
ppl
reverse
ppl
setq
3dppl
append
3dppl 3dppl
setq
ppl
mapcar
lambda
a b
list
a b
ppl
cdr
reverse
cons
car
ppl
reverse
ppl
foreach
pp ppl
setq
pos1
vl
position
fuzz
car
pp
3dppl 1e
6
pos2
vl
position
fuzz
cadr
pp
3dppl 1e
6
k
1
if
pos2 pos1
setq
pos2
pos2
vl
position
fuzz
cadr
pp
cdr
vl
member
if
lambda
x
equal
x
cadr
pp
1e
6
3dppl
1e
6
1
foreach
p 3dppl
setq
k
1+
k
if
pos1 k pos2
setq
ppp
cons
p ppp
setq
3dppls
cons
ppp 3dppls
setq
ppp
nil
foreach
ppp 3dppls
vl-cmdf
"_.3DPOLY"
foreach
p ppp
vl-cmdf
"_non"
p
vl-cmdf
setq
3dppl
nil
3dppls
nil
ppl
nil
progn
setq
3dppl
cons
p2 3dppl
vl-cmdf
"_.3DPOLY"
foreach
p 3dppl
vl-cmdf
"_non"
p
vl-cmdf
"_C"
setq
3dppl
nil
setvar
'osmode osm
setvar
'pdmode pdm
setvar
'pdsize pds
prompt
\n
Elapsed time : "
princ
rtos
car
_vl-times
ti
1000.0
2
50
prompt
" seconds..."
princ
For more info, serach this topic...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/draw-3dpoly-in-3dfaces/m-p/7789616#M365239
Regards, M.R.
P.S. You could ask someone that work in .NET or ObjectARX like nullptr-aka Daniel to convert this lisp to something faster as it's not fast algorithm at all...
But it's LISP and you can understand it...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
well20152016
Newt
Reply #3 on:
December 03, 2018, 11:01:23 PM »
Thank you!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
