Author Topic: Where did you start when learning Dynamo  (Read 3979 times)
Hangman
« on: November 28, 2018, 10:31:28 AM »
I am curious (as I hope others are as well) as to where you started when learning Dynamo?
Did you have a formal class?
Did you buy books?  If so, which ones?
Did you buy learning videos? If so, which ones?
Did you learn Dynamo via Youtube / Dynamobim.org / Hudsters recommended sites (http://www.theswamp.org/index.php?topic=50772.0) / etc & struggle through trial & error?
Your suggestions on where & how to start learning it effectively would be greatly appreciated as well.
Hangman  8)
Hangman
Re: Where did you start when learning Dynamo
« Reply #1 on: November 28, 2018, 10:42:50 AM »
I wanted to start this chat in hopes of learning a little more about how you got started in dynamo & where one can go for more information.
I've been struggling with learning dynamo for almost a year now, going to dynamobim.org/learn, the dynamoprimer.com, & have realized I keep reading over the same materials.  My trial & error method is more error in trial & it's getting really frustrating when I want to put together a simple routine & can't make it happen.  I think I need a more structured learning but I can't find any books & the learning classes from only one vendor that I can find are expensive & not in tune with my time table.
So, ... how are you doing (or did) it?
Hangman  8)
