Author Topic: adding angle limit to lisp code "  (Read 1582 times)
jtm2020hyo
« on: November 18, 2018, 04:02:55 PM »
I attached 2 files that work in same way.
Is possible to add limiting options to allow code work just in a certain range of angles or ignore block between certain angles choice for the user?
I want to use this code to link just with blocks that are between an angle range of 0 grades (variable) and 180 grades ( variable) respect to block base point and their rotation, I need to ignore all block between 180 grades and 360 grades respect to block base point and their rotation.
Re: adding angle limit to lisp code "
« Reply #1 on: November 26, 2018, 02:58:26 PM »
This will filter blocks with a rotation less than or equal to 180 degrees.
  1. (sssetfirst nil (ssget "_A" (list '(0 . "INSERT") '(-4 . "<=") (cons 50 pi))))
