Author Topic: If statement. Layer gets made but color won't set.  (Read 4817 times)
jlogan02
Re: If statement. Layer gets made but color won't set.
« Reply #15 on: November 27, 2018, 04:50:05 PM »
So here's my result with your suggestion for using wcmatch. Worked nicely and shortened the routine. Like it!
  1. (defun c:ST136to191 (/ *error* osm cl136 fm136 ss attValue)
  2.   (defun *error* ( msg )
  3.         (if osm (setvar 'osmode osm))
  4.         (if (not (member msg '("Function cancelled" "quit / exit abort")))
  5.             (princ (strcat "\nError: " msg))
  6.         )
  7.         (princ)
  8.     )
  9.
  10.     (setq osm (getvar 'osmode))
  11.     (setvar 'osmode 0)
  12.     (setvar 'cmdecho 0)
  13.   (defun LM:GetAttributeValue (blk tag / val enx)
  14.     (while
  15.       (and
  16.         (null val)
  17.         (= "ATTRIB"
  18.            (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))
  19.         )
  20.       )
  21.        (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
  22.          (setq val (cdr (assoc 1 enx)))
  23.        )
  24.     )
  25.   )
  26.
  27.    (setq cl136 (ssget "x" '((62 . 136)(0 . "LINE,POLYLINE,LWPOLYLINE,TEXT,MTEXT"))))
  28.      (command "_chprop" cl136 "" "_COLOR" "191" (command)(command))
  29.
  30.     (setq ss (ssget "x" '((0 . "INSERT") (2 . "TBLK_ATT_CTL")(66 . 1))))
  31.     (setq attValue (LM:GetAttributeValue (ssname ss 0) "TITLELINE4"))
  32.
  33.  (cond ((wcmatch (strcase attvalue) "EQUIPMENT PLAN,INTERIOR ELEVATIONS")
  34.        (setq fm136 (ssget "x" '((8 . "FiberMgt_136"))))
  35.         (command "._Layer" "Make" "FiberMgt_191" "_Color" "191" "FiberMgt_191" "Make" "FiberMgt_1" "Color" "RED" (command)(command))
  36.         (command "_chprop" fm136 "" "LA" "FiberMgt_191" "" (command)(command))
  37.         (command "._layer" "filter" "edit" "Stations Standard Layers" "add" "FiberMgt_191" "exit" (command)(command))
  38.   )
  39. )
  40.  (rtos (getreal "\nPress Esc to exit, press Enter to force an error ..."))
  41.
  42.     (setvar 'osmode osm)
  43.   (setvar 'cmdecho 1)
  44.
  45.   (princ)
  46. )
I get...
Command: ST136TO191
Unknown command "ST136TO191".  Press F1 for help.
I've looked for spaces and missing spaces. Just can't find the issue.
J. Logan
ACAD2019
« Last Edit: November 27, 2018, 04:53:34 PM by jlogan02 »
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
« Reply #16 on: November 27, 2018, 05:03:52 PM »
First thing that looks strange is all the (command)(command) calls?
 Maybe "._layer" should be ".-layer" ?
« Last Edit: November 27, 2018, 05:13:35 PM by ronjonp »
« Reply #17 on: November 27, 2018, 05:22:09 PM »
Here's a quick ( untested ) stab at removing some of the command calls:
  1. (defun c:st136to191 (/ *error* osm cl136 fm136 ss attvalue)
  2.   (defun _addlayer (name color ltype plot)
  3.     (cond ((not (tblsearch "layer" name))
  4.            (entmakex (list '(0 . "LAYER")
  5.                            '(100 . "AcDbSymbolTableRecord")
  6.                            '(100 . "AcDbLayerTableRecord")
  7.                            '(70 . 0)
  8.                            (cons 2 name)
  9.                            (cons 62 color)
  10.                            (cons 6
  11.                                  (cond ((tblobjname "ltype" ltype))
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  16.                            ;;1 = plottable 0 = not=plottable
  17.                      )
  18.            )
  19.           )
  20.           ((tblobjname "layer" name))
  21.     )
  22.   )
  23.   (defun *error* (msg)
  24.     (if osm
  25.       (setvar 'osmode osm)
  26.     )
  27.     (if (not (member msg '("Function cancelled" "quit / exit abort")))
  28.       (princ (strcat "\nError: " msg))
  29.     )
  30.     (princ)
  31.   )
  32.   (setq osm (getvar 'osmode))
  33.   (setvar 'osmode 0)
  34.   (setvar 'cmdecho 0)
  35.   (defun lm:getattributevalue (blk tag / val enx)
  36.     (while
  37.       (and (null val) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))))
  38.        (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
  39.          (setq val (cdr (assoc 1 enx)))
  40.        )
  41.     )
  42.   )
  43.   (if (setq cl136 (ssget "x" '((62 . 136) (0 . "LINE,POLYLINE,LWPOLYLINE,TEXT,MTEXT"))))
  44.     (foreach x (mapcar 'cadr (ssnamex cl136)) (entmod (append (entget x) '((62 . 191)))))
  45.   )
  46.   (setq ss (ssget "x" '((0 . "INSERT") (2 . "TBLK_ATT_CTL") (66 . 1))))
  47.   (setq attvalue (lm:getattributevalue (ssname ss 0) "TITLELINE4"))
  48.   (cond ((wcmatch (strcase attvalue) "EQUIPMENT PLAN,INTERIOR ELEVATIONS")
  49.          (_addlayer "FiberMgt_191" 191 "Continous" 1)
  50.          (_addlayer "FiberMgt_1" 1 "Continous" 1)
  51.          (if (setq fm136 (ssget "x" '((8 . "FiberMgt_136"))))
  52.            (foreach x (mapcar 'cadr (ssnamex fm136))
  53.              (entmod (append (entget x) '((8 . "FiberMgt_191"))))
  54.            )
  55.          )
  56.          ;; Changed to -layer
  57.          (command ".-layer"
  58.                   "filter"
  59.                   "edit"
  60.                   "Stations Standard Layers"
  61.                   "add"
  62.                   "FiberMgt_191"
  63.                   "exit"
  64.                   (command)
  65.                   (command)
  66.          )
  67.         )
  68.   )
  69.   ;; Why this?
  70.   (rtos (getreal "\nPress Esc to exit, press Enter to force an error ..."))
  71.   (setvar 'osmode osm)
  72.   (setvar 'cmdecho 1)
  73.   (princ)
  74. )
jlogan02
« Reply #18 on: November 29, 2018, 12:10:57 PM »
Sorry Ron, I didn't see this post. I had the command calls in there because it seemed that was the only way I could avoid getting "Unknown command..." errors at the command line.
I've been assuming I'm getting those because I'm ending the Change properties commands or the layers commands wrong/ungracefully. that was my fix. Perhaps I'm mistaken. I don't know how the message at the end got left in there. I did have error checking in it but removed it, well not all of it, while testing.
J. Logan
ACAD 2018
J. Logan
ACAD 2018
