Author Topic: Merging all drawing files from a folder into a single drawing file  (Read 2043 times)
suresh991
Actually my requirement is to merge the drawing files from folder into a single drawing file and the scale of the data should not change and the each drawing file data should be arrange in an order in the new drawing file
Thank you and Warm Regards
Suresh
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Merging all drawing files from a folder into a single drawing file
« Reply #1 on: November 12, 2018, 12:25:46 AM »
Welcome to theSwamp.
Areyou able to program in C# or VB ?
What have yo tried so far ?
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: November 12, 2018, 03:20:33 AM »
.NETs version of AcDbDatabase::insert (AcGeMatrix3d&, AcDbDatabase*, bool) ?
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: November 12, 2018, 08:37:29 PM »
Using old fashioned script would do what you want very simply using a  -insert command
-insert dwg1 0,0 1 1  0
-insert dwg2 100,100 1 1 0
There are lots of ways of making the script if its something you do all the time then a lisp etc could be used to make the list of drawing names and write script file.
