Author Topic: Null object Id  (Read 1774 times)
GDF
Null object Id
« on: November 09, 2018, 03:47:42 PM »
I have just got this error message when using BricsCAD Drawing Compare. Any ideals?
It only happens on a few drawings.
Null object Id: <object> (0)
BricsCAD 2019x64 Windows 10x64
Re: Null object Id
« Reply #1 on: November 09, 2018, 04:22:09 PM »
did those drawings start in autodcad?
can you perform a PURGE and AUDIT on one of the files that produce the error, and then compare them after?
  • BricsCAD
Re: Null object Id
« Reply #2 on: November 10, 2018, 12:24:03 AM »
oh, I thought you were talking about me  :|
GDF
Re: Null object Id
« Reply #3 on: November 12, 2018, 05:35:30 AM »
Interesting...the original drawing was started in AutoCAD and the drawing to compare was a save as drawing in BricsCAD with changes. Only a few drawings give out this error message.
Yes I have purged and wblocked out all of the drawings using BricsCAD.
Iím at a loss as to what to do?
  • BricsCAD
Re: Null object Id
« Reply #4 on: November 12, 2018, 06:37:22 AM »
I think the guys at Bricsys might be able to help, you might file support request.
GDF
Re: Null object Id
« Reply #5 on: November 12, 2018, 09:10:07 AM »
Posted on the BricsCAD forum...
  • BricsCAD
Re: Null object Id
« Reply #6 on: November 13, 2018, 08:14:44 PM »
You're probably not going to get much help there, the best thing to do is file a support request and attach the offending drawings.
They can step through the code with a debugger and find the exact problem. In fact, I'm sure Bricsys would like having feedback.
especially since there's a (Carl Sagan, billions and billions) things that can happen to a drawing
Cheers :)
kdub
  • SuperMod
Re: Null object Id
« Reply #7 on: November 14, 2018, 11:55:43 AM »
...  since there's a (Carl Sagan, billions and billions) things that can happen ....
Cheers :)
Thanks for the nudge Daniel ... That man has some interesting quotes.
called Kerry in my other life
#ridesober
Atook
Re: Null object Id
« Reply #8 on: November 14, 2018, 11:58:03 AM »
Quote from: nullptr
Seconded. I've found BricsCAD support team to be helpful. A welcome surprise after years of Autodesk 'developer support'.
