Author Topic: DXF 8 (layer) on BLOCK definition  (Read 2852 times)
Marc'Antonio Alessi
  • Marco
« on: November 09, 2018, 10:24:23 AM »
What is it for (8 . "0")  >  Layer = "0"  on BLOCK definition?
((-1 . <Nome entità: 7ff4a3d5a370>)
(0 . "BLOCK") (330 . <Nome entità: 7ff4a3d5a360>)
(5 . "FDA5F") (100 . "AcDbEntity")
(67 . 0)
(8 . "0")
(100 . "AcDbBlockBegin")
(70 . 0) (10 100.0 100.0 0.0)
(-2 . <Nome entità: 7ff4a3d5a380>)
(2 . "pippo")
(1 . "pippo"))
; IAcadEntity: Interfaccia entità AutoCAD
; valori della proprietà:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff68e713318>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000002fceef28>
;   EntityTransparency = "DaLayer"
;   Handle (RO) = "FDA70"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000002fe087e8>
;   Layer = "0"
;   Linetype = "BYLAYER"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   ObjectID (RO) = 152
;   ObjectID32 (RO) = 152
;   ObjectName (RO) = "AcDbBlockBegin"
;   OwnerID (RO) = 153
;   OwnerID32 (RO) = 153
;   PlotStyleName = "ByLayer"
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000002fe08ea0>
;   Visible = -1
Re: DXF 8 (layer) on BLOCK definition
« Reply #1 on: November 09, 2018, 05:48:16 PM »
I would always suggest using layer "0" for the BLOCK and ENDBLK entities, else layers assigned to these entities cannot be purged; as far as I'm aware, the layer assigned to these entities have no graphical effect on the resulting block reference.
kirby
« Reply #2 on: November 09, 2018, 06:25:55 PM »
May just be part of a standard entity definition. eg. Layer of 'header' entity of heavy polyline has a layer, so does a block definition.  I know drawing can go haywire if a polyline vertices are edited onto a different layer than the header, but same isn't true about block definition.
Marc'Antonio Alessi
  • Marco
« Reply #3 on: November 10, 2018, 11:24:51 AM »
Thanks, I'm trying to write a function that speeds up block creations, suggestions?
(setq #OneEnt (entlast)  #Countr 0)
 (Benchmark '(
 (test_EntMake1 #OneEnt)
 (test_EntMake2 #OneEnt)
 (test_vl-cmdf1 #OneEnt)
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 2048 iteration(s):
    (TEST_ENTMAKE2 #ONEENT)......4891 / 2.45 <fastest>
    (TEST_ENTMAKE1 #ONEENT)......6218 / 1.93
    (TEST_VL-CMDF1 #ONEENT).....11984 / 1 <slowest>
>TEST_ENTMAKE1 with (tblsearch "BLOCK" BlkNam) is slower
(defun test_EntMake1 (SsOrEn)
  (ALE_Block_Draw_EntMake1 SsOrEn (strcat "EntMake1" (itoa (setq #Countr (1+ #Countr)))) '(0. 0. 0.))
  (entdel SsOrEn)
(defun test_EntMake2 (SsOrEn)
  (ALE_Block_Draw_EntMake2 SsOrEn (strcat "EntMake1" (itoa (setq #Countr (1+ #Countr)))) '(0. 0. 0.))
  (entdel SsOrEn)
(defun test_vl-cmdf1 (SsOrEn)
  (ALE_Block_Draw_vl-cmdf SsOrEn (strcat "vl-cmdf" (itoa (setq #Countr (1+ #Countr)))) '(0. 0. 0.))
  (entdel SsOrEn)
(defun ALE_Block_Draw_EntMake1 (SsOrEn BlkNam BlkIns)
    ( (not (snvalid BlkNam))     (alert (strcat  BlkNam ": nome non valido per la creazione del blocco.")) ) ;restituisce nil
    ( (tblsearch "BLOCK" BlkNam) (alert (strcat  BlkNam ": blocco già esistente.")) ) ;restituisce nil
    ( (entmake
        (list
         '(0   . "BLOCK")
         '(100 . "AcDbEntity")         ; recommended
         '(100 . "AcDbBlockBegin")     ; recommended
          (cons  2 BlkNam)             ; required
         '(8  . "0")                   ; recommended
         '(70 .  0)                    ; required [NOTE 0 if no attributes]
          (cons 10 (trans BlkIns 1 0)) ; required trans da eventuale User (current UCS) a World (WCS)
      (if (equal (type SsOrEn) 'PICKSET)
        (foreach ForElm (vl-remove-if 'listp (mapcar 'cadr (ssnamex SsOrEn))) ; nuovo metodo per elaborare entità in un gruppo di selezione
          (if (entmake (entget ForElm))
            (entdel ForElm)
            (alert (strcat "errore 1 nella creazione del blocco: " BlkNam))
        (if (entmake (entget SsOrEn))
          (entdel SsOrEn)
          (alert (strcat "errore 2 nella creazione del blocco: " BlkNam))
      (entmake '((0 . "ENDBLK") (8 . "0") (100 . "AcDbBlockEnd"))) ; restituisce BlkNam se buon fine
    ( T (alert (strcat "errore 3 nella creazione del blocco: " BlkNam)) ) ;restituisce nil
(defun ALE_Block_Draw_EntMake2 (SsOrEn BlkNam BlkIns)
    ( (entmake
        (list
         '(0   . "BLOCK")
            (entdel ForElm)
          (entdel SsOrEn)
(defun ALE_Block_Draw_vl-cmdf (SsOrEn BlkNam BlkIns)
  (vl-cmdf "_.BLOCK" BlkNam BlkIns SsOrEn "")
« Reply #4 on: November 10, 2018, 12:21:19 PM »
If you're looking for performance, avoid ssnamex - this is known to be slow.
You may wish to consider the methods used in these programs.
efernal
« Reply #5 on: November 10, 2018, 04:23:15 PM »
My tools ...
I do not send .dwg files, but .fas files, which are much smaller and efficient ...
e.fernal
Marc'Antonio Alessi
  • Marco
« Reply #6 on: November 11, 2018, 03:20:54 AM »
My tools ...
Interesting, never had this idea... do you think this method is valid even for very large files?
Better than DXF?
Marc'Antonio Alessi
  • Marco
« Reply #7 on: November 11, 2018, 03:51:13 AM »
Lee, I had already seen your link… all the comments are from CAB:
'(100. "AcDbEntity"); recommended
'(100. "AcDbBlockBegin"); recommended
(cons 2 BlkNam); required
'(8. "0"); recommended
you're right repeat is faster, and to think that once I used it... now I have to go back to the old road:
(defun test_ssnamex (SsOrEn)
    (entget ForElm)
(defun test_repeat (SsOrEn / i)
  (repeat (setq i (sslength SsOrEn))
    (entget (ssname SsOrEn (setq i (1- i))))
(sslength (setq Aselset (ssget "_X"))) > 14672
(Benchmark '(
 (test_ssnamex Aselset)
 (test_repeat Aselset)
Elapsed milliseconds / relative speed for 8 iteration(s):
    (TEST_REPEAT ASELSET)......1172 / 1.27 <fastest>
    (TEST_REPEAT ASELSET)......1187 / 1.25
    (TEST_SSNAMEX ASELSET).....1453 / 1.02
    (TEST_SSNAMEX ASELSET).....1484 / 1 <slowest>
efernal
« Reply #8 on: November 11, 2018, 06:31:42 PM »
Better than DXF?
I use this (and others) functions to build blocks, styles, layers, etc, extracting the data direct from these entities...
e.fernal
