Author Topic: (C3D 2019) Jumping cursor.  (Read 6987 times)
« on: November 08, 2018, 10:39:50 AM »
All of the sudden the crosshairs are jumping like grid snap is on. Tried all the usual stuff but nothing works. Anyone else having this problem? It is so bad i can't even work!
Re: (C3D 2019) Jumping cursor.
« Reply #1 on: November 08, 2018, 10:51:55 AM »
No jumping cursor here but 2019.1.1 definitely introduced a selection bug.
https://forums.autodesk.com/t5/autocad-forum/object-selection-issues-with-new-2019-1-1-update/td-p/8248509
« Reply #2 on: November 08, 2018, 11:12:08 AM »
I've had that update installed for a week now without issues. I believe we got a OS update last night so that may have something to do with it. Changing workspaces seems to make it worse. Changing profiles has no affect.
« Reply #3 on: November 08, 2018, 11:14:01 AM »
Try Decaf?
« Reply #4 on: November 08, 2018, 11:17:23 AM »
oh...perhaps check that you are in plan view/world ucs
I had this cause some issues once, recently 3d snap was somehow involved
« Reply #5 on: November 08, 2018, 11:32:56 AM »
Did that too. Let me check 3d snap though. I'm pretty sure that is off but ...........
« Reply #6 on: November 08, 2018, 11:57:56 AM »
is  UCSDETECT in AutoCAD set to 0 (zero)?
do you have selection cycling on?
« Reply #7 on: November 08, 2018, 12:10:02 PM »
It is now. No difference.
Selection cycling is off as well.
« Reply #8 on: November 08, 2018, 12:10:50 PM »
It seems to get worse the longer acad in running. :-/
« Reply #9 on: November 08, 2018, 12:11:43 PM »
Could be graphic card specific. What card are you running?
« Reply #10 on: November 08, 2018, 12:14:31 PM »
Card name: NVIDIA Quadro M2000
Driver version: 23.21.13.9174
Tuning Date: 11/8/2018
Virtual device: Dx11 (Hardware)
The card and driver meets the recommended requirement.
« Reply #11 on: November 08, 2018, 12:49:13 PM »
Quick search found this .. it's very recent too.
https://goo.gl/ZDpK2z
« Reply #12 on: November 08, 2018, 01:22:14 PM »
Thanks Ron i saw that earlier. Let me try updating the drivers then repair the install.
« Reply #13 on: November 08, 2018, 01:45:35 PM »
New driver, same problem. :-/
« Reply #14 on: November 08, 2018, 01:56:57 PM »
try to get an older driver....not like the real old ones in Florida....but old for your video card.
