Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help ME re - format code
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help ME re - format code (Read 1538 times)
HOSNEYALAA
Newt
on:
November 07, 2018, 01:40:12 AM »
I have a code that gives the point the height of the nearest TEXT of the point
Is it possible to choose points and numbers at once?
And the requirement that the number of Texts equal the number of characters until the code works
Thanks a lot to everyone.
Code - Auto/Visual Lisp:
[Select]
defun
c:DTP
AP AT DD END1 END2 H HH HTT I II J LEN NP NT XL1 XL2 YL1 YL2 ZND2
ALERT
"Required number of points = number of writings"
command
"layer"
"m"
"NEW_TXT"
command
"color"
"t"
"253,176,23"
command
"CMDECHO"
"0"
princ
\n
Select POINT :"
SETQ
AP
SSGET
LIST
CONS
0
"POINT"
princ
\n
Select POINT :"
setq
NP
sslength
AP
; No of POINT
princ
\n
Select TEXT :"
SETQ
AT
SSGET
LIST
CONS
0
"TEXT,MTEXT"
princ
\n
Select TEXT,MTEXT :"
setq
NT
sslength
AT
; No of TEXT
setq
I
0
; Order of POINT
setq
II
0
; Order of TEXT
setq
DD
100
; No. of Intersection
while
I NP
while
II NT
setq
END1
cdr
assoc
10
entget
ssname
AP I
; Get Point
setq
END2
cdr
assoc
10
entget
ssname
AT II
; GetTEXT
setq
ZND2
ATOF
cdr
assoc
1
entget
ssname
AT II
; GetTEXT
setq
XL1
car
END1
; Get X cordinate for START POINT.
setq
YL1
cadr
END1
; Get Y cordinate for START POINT.
setq
XL2
car
END2
; Get X cordinate for END TEXT.
setq
YL2
cadr
END2
; Get Y cordinate for END TEXT.
setq
len
sqrt
ABS
expt
YL2 YL1
2
expt
XL2 XL1
2
if
LEN DD
progn
setq
hh
list
XL1 YL1 ZND2
setq
DD LEN
progn
setq
h
list
XL1 YL1
SETQ
II
1
II
;while
SETQ
htT
RTOS
CADDR
HH
2
2
command
"._Text"
"j"
"mc"
HH
2
"0"
htt
command
"._point"
hh
;;; (command "._Change" (entlast) "" "p" "ELEV" "ZND2" "")
setq
II
0
SETQ
I
1
I
setq
DD
100
;while
EDIT (John): Added code tags to post for formatting.
Last Edit: November 07, 2018, 07:25:38 AM by John Kaul (Se7en)
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Help ME re - format code
Reply #1 on:
February 06, 2019, 07:54:57 PM »
Just search this has been answered many times using a distance between point and text.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
