Author Topic: Grating Lisp that needs help  (Read 2237 times)
laisonalbarado
« on: November 05, 2018, 01:11:23 PM »
HEllo,
I ran across this grating lisp file online. I tried to use it but there is an error in it. If someone can take a look at it and I would appreciate it.
;GRADING.LSP (C:TAG)
;This routine is used mainly on grading plans to show elevations of
;certain features like back-of-curb, valley gutters, etc. . .
;The AutoCAD variable LTSCALE determines the size of the tags.
;Four different types of elevation tags are available.  Single tags
;show an elevation over a description.  Double tags show two elevations
;i.e. 2100.39 TC \ 2099.89 AC.  Box tags show a single elevation with
;a box around it.  Longbox tags show a single elevation with a longer
;box to allow a decrtiption as well.
;The leader lines can either be fixed or variable.  Fixed leaders are
;part of the elevation tag block and are therefore easier to move, copy
;or erase later.  Variabl leaders are not part of the block and are use-
;ful in tight spaces.
;You have the option of inserting a point block that can be used by rou-
;tines in other civil software packages such as Softdesk's AdCADD pack-
;ages.  This point block is inserted along with the elevation tag.  The
;elevation of the point will be determined from the value of the elev-
;ation tag.  Tagging from points will allow you to insert elevation tags
;at the insertion points of existing point blocks and using their values
;for the elevation and description of the tag.
;The blocks with the `GT' prefix (i.e. GTBF1.DWG) and the POINT.DWG are
;used by this routine.
(defun getatt (blkent atttag / blked entype attval atag)
  (setq blked (entget blkent)
        entype (cdr (assoc 0 blked))
        attval nil
  (if (= entype "INSERT")
    (while (/= entype "SEQEND")
      (setq blkent (entnext blkent)
            atag (cdr (assoc 2 blked))
      (if (= atag atttag)
        (setq attval (cdr (assoc 1 blked))
              entype "SEQEND"
    (prompt "\nEntity selected is not a block.")
  attval
(defun putatt (blkent atttag attval / blked entype putokay atag oldval newval)
        putokay 0
      (if (= atag atttag)
          (setq oldval (assoc 1 blked)
                newval (cons 1 attval)
                blked (subst newval oldval blked)
                entype "SEQEND"
                putokay -1
          (entmod blked)
          (entupd (cdr (assoc -1 blked)))
  putokay
(defun kent (kwd msg def / inp)
  (setq msg (strcat "\n" msg " (" kwd ") <" def ">: ")
        oldos (getvar "OSMODE")
  (setvar "OSMODE" 1536)
  (initget kwd)
  (setq inp (getpoint msg))
  (setvar "OSMODE" oldos)
    ((= (type inp) 'STR) inp)
    ((= (type inp) 'LIST)
      (if (setq ss (ssget inp))
        (ssname ss 0)
        nil
    ((not inp) def)
(defun kword (bit kwd msg def / inp)
  (if (and def (/= def ""))
          bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg " (" kwd "): "))
  (initget bit kwd)
  (setq inp (getkword msg))
  (if inp inp def)
(defun kstr (bit msg def spflag / inp nval)
    (setq msg (strcat "\n" msg " <" def ">: ")
          inp (getstring msg spflag)
          inp (if (= inp "") def inp)
      (setq msg (strcat "\n" msg ": "))
      (if (= bit 1)
        (while (= "" (setq inp (getstring msg spflag))))
  inp
(defun kpoint (bit kwd msg def bpt / inp)
  (if def
    (setq pts (strcat (rtos (car def)) "," (rtos (cadr def))
    (if (and (caddr def) (= 0 (getvar "FLATLAND")))
      (strcat "," (rtos (caddr def)))
  msg (strcat "\n" msg " (" kwd ") <" pts ">: ")
  (initget bit kwd)
  (setq inp
    (if bpt
      (getpoint msg bpt)
      (getpoint msg)
  (if inp inp def)
(defun setquad (ldrang)
    ((and (>= ldrang 0) (< ldrang (/ PI 2)))
      "1"
    ((and (>= ldrang (/ PI 2)) (< ldrang PI))
      "4"
    ((and (>= ldrang PI) (< ldrang (* PI 1.5)))
      "3"
    ((and (>= ldrang (* PI 1.5)) (< ldrang (* PI 2.0)))
      "2"
(defun stag (inspt tagtype ldrtype autocode CHC_PTH)
  (setq pt2 (getpoint inspt "\nSecond point")
     ldrang (angle inspt pt2)
   quadrant (setquad ldrang)
  (if (= tagtype "Single")
    (setq pretag (CHC_PTH "L:/BLOCKS/GT")
            udef "0000.00"
            ldef "T.C."
    (setq pretag (CHC_PTH "L:/BLOCKS/GTD")
            udef "0000.00 T.C."
            ldef "0000.00 A.C."
  (if (not autocode)
    (setq uval (kstr 0 "Upper tag value" udef T)
          lval (kstr 0 "Lower tag value" ldef T)
  (command ".UNDO" "M")
  (if (and (= dopoint "Yes") (not autocode))
      (command ".INSERT" (CHC_PTH "L:/BLOCKS/POINT") "S" (getvar "LTSCALE") inspt blkang uval ptnum lval)
      (setq ptnum (1+ ptnum))
  (if (= ldrtype "Fixed")
      (command ".INSERT" (strcat pretag "F" quadrant) "S" (getvar "LTSCALE") inspt blkang uval lval)
      (command ".DONUT" 0.0 (* 0.03 (getvar "LTSCALE")) inspt "")
      (command ".LINE" inspt pt2 "")
      (if (or (= quadrant "1") (= quadrant "2"))
        (setq tagblk (strcat pretag "R"))
        (setq tagblk (strcat pretag "L"))
      (command ".INSERT" tagblk "S" (getvar "LTSCALE") pt2 blkang uval lval)
(defun boxtag (inspt ldrtype)
  (setq pt2 (getpoint inspt "Second point")
       uval (kstr 0 "Box tag value" "000.00" T)
  (if (= tagtype "Longbox")
    (setq pretag (CHC_PTH "L:/BLOCKS/"))
  (if (= dopoint "Yes")
    (command ".INSERT" (strcat pretag "f" quadrant) "S" (getvar "LTSCALE") inspt blkang uval)
      (command ".DONUT" (* 0.0 (getvar "LTSCALE")) (* 0.03 (getvar "LTSCALE")) inspt "")
      (setq tagblk (strcat pretag quadrant))
      (command ".INSERT" tagblk "S" (getvar "LTSCALE") pt2 blkang uval)
(defun tagpnts ( / exitcode en ptent inspt uval lval)
  (setq exitcode nil
        desctype (kword 0 "User Desc" "User defined or point descriptions" "User")
  (while (not exitcode)
    (setq en (kent "Undo Multiple Leader Tags" "Pick a point block" "Tags"))
      ((= en "Multiple")
        (multipt)
      ((= en "Leader")
        (setq ldrtype (kword 0 "Fixed Variable" "Leader type" "Fixed"))
      ((= en "Tags")
        (setq exitcode 1)
      ((= en "Undo")
        (command ".UNDO" "B")
      (en
        (if (setq uval (getatt en "ELEV"))
            (setq ptent (entget en)
                  inspt (cdr (assoc 10 ptent))
            (if (= desctype "User")
              (setq lval (kstr 0 "Tag Description" "T.C." T))
              (setq lval (getatt en "DESC"))
            (stag inspt "Single" ldrtype 1)
          (prompt " Try again.")
(defun multipt ( / ptss numpts count blkn ed inspt uval lval)
  (prompt "\nSelect grading points: ")
  (setq ptss (ssget)
        numpts (sslength ptss)
        count 0
  (if (> numpts 0)
    (while (< count numpts)
      (setq blkn (ssname ptss count)
            ed (entget blkn)
            inspt (cdr (assoc 10 ed))
      (if (and (= (cdr (assoc 0 ed)) "INSERT")
               (= (cdr (assoc 2 ed)) "POINT")
               (setq uval (getatt blkn "ELEV"))
            (setq lval (getatt blkn "DESC"))
      (setq count (1+ count))
(defun C:TAG ()
  (setq blkang (angtos (getvar "SNAPANG") (getvar "AUNITS") (getvar "AUPREC")))
  (if (not ldrtype)
    (setq ldrtype "Variable"
          tagtype "Single"
  (setq dopoint (kword 0 "Yes No" "Do you want grading points inserted" "No")
  (if (or (not ptnum) (/= (type ptnum) 'INT))
    (setq ptnum 1)
  (while (setq inspt (kpoint 0 "Points Leader Type Undo" "Insertion point" nil nil))
      ((= inspt "Leader")
        (setq ldrtype (kword 0 "Fixed Variable" "Leader Type" "Variable"))
      ((= inspt "Points")
        (tagpnts)
      ((= inspt "Type")
        (setq tagtype (kword 0 "Single Double Box Longbox" "Tag Type" "Single"))
      ((= inspt "Undo")
      (inspt
        (if (or (= tagtype "Single") (= tagtype "Double"))
          (stag inspt tagtype ldrtype nil)
          (boxtag inspt ldrtype)
ChrisCarlson
Re: Grating Lisp that needs help
« Reply #1 on: November 05, 2018, 02:26:48 PM »
What is the error?
laisonalbarado
« Reply #2 on: November 07, 2018, 09:50:38 AM »
I don't have a clue.
« Reply #3 on: November 07, 2018, 11:57:59 AM »
Do you have the blocks?
ChrisCarlson
« Reply #4 on: November 07, 2018, 12:50:55 PM »
When you run the lisp routine, what does the AutoCAD command prompt say?
