Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Shortest Path between two points on grid and cover all points
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Shortest Path between two points on grid and cover all points (Read 11929 times)
ribarm
Gator
Marko Ribar, architect
WWW
Re: Shortest Path between two points on grid and cover all points
Reply #15 on:
January 04, 2019, 05:03:45 AM »
My latest revision according to newly posted code for 2D TSP topic started by Evgeniy Elpanov...
Code - Auto/Visual Lisp:
[Select]
defun
c:TSP
2D
MR
START
END
car
sort plstdiff processrs ss ti i pl pln k plp pld pll d r rr ppp lil lii1 lii2 lil1 lil2 lil3 ip f kk n
;;; (car-sort '(2 4 1 3 5 1) '<) => nil
;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
defun
car
sort
l f
removenth r k
defun
removenth
l n
k
setq
k
1
vl
remove
if
function
lambda
x
setq
k
1+
k
n
l
setq
k
1
vl-some
function
lambda
a
setq
k
1+
k
if
vl-every
function
lambda
x
apply
f
list
a x
removenth l k
setq
r a
l
r
defun
plstdiff
l1 l2
foreach
p l1
setq
l2
vl-remove
p l2
l2
defun
processrs
r
rr
foreach
xx r
if
and
null
f
if
equal
xx pln
setq
ppp pl
setq
ppp
plstdiff xx pl
foreach
p ppp
setq
k
1
repeat
1-
length
xx
setq
k
1+
k
setq
plp
reverse
member
nth
k xx
reverse
xx
setq
pls
cdr
member
nth
k xx
xx
setq
pll
append
plp
list
p
pls
setq
rr
cons
pll rr
setq
f t
if
f
progn
setq
pl
nil
r
if
kk n
progn
setq
kk
0
setq
rr
mapcar
function
lambda
x
list
apply
function
mapcar
function
lambda
a b
distance
a b
x
cdr
x
x
rr
setq
rr
list
cadr
car
sort rr
function
lambda
a b
car
a
car
b
rr
setq
ss
ssget
0
"POINT"
repeat
setq
i
sslength
ss
setq
pl
cons
mapcar
function
0
0
cdr
assoc
10
entget
ssname
ss
setq
i
1-
i
pl
initget
1
setq
sp
mapcar
function
0
0
trans
getpoint
\n
Start/end point from selection set : "
1
0
initget
1
setq
ep
mapcar
function
0
0
trans
getpoint
\n
End/start point from selection set : "
1
0
initget
6
setq
n
getint
\n
Specify speed factor - reliability - [1-fast/2-slow] <1> : "
if
null
n
setq
n
1
setq
ti
car
_vl-times
setq
pln
list
sp ep
setq
pl
vl-remove
sp pl
pl
vl-remove
ep pl
setq
kk
0
while
pl
setq
kk
1+
kk
if
null
rr
setq
rr
processrs
list
pln
setq
rr
processrs rr
setq
rr
mapcar
function
lambda
x
list
apply
function
mapcar
function
lambda
a b
distance
a b
x
cdr
x
x
rr
setq
pln
cadr
car
sort rr
function
lambda
a b
car
a
car
b
setq
lil
mapcar
function
lambda
a b
list
a b
pln
cdr
pln
while
vl-some
function
lambda
li1
vl-some
function
lambda
li2
if
and
setq
ip
inters
car
li1
cadr
li1
car
li2
cadr
li2
not
equal
ip
car
li1
1e
8
not
equal
ip
cadr
li1
1e
8
not
equal
ip
car
li2
1e
8
not
equal
ip
cadr
li2
1e
8
setq
lii1 li1 lii2 li2
vl-remove
li1 lil
lil
if
vl-position
lii1 lil
vl-position
lii2 lil
mapcar
function
set
lii1 lii2
list
lii2 lii1
setq
lil1
reverse
cdr
member
lii1
reverse
lil
setq
lil2
cdr
member
lii2
reverse
cdr
member
lii1 lil
setq
lil3
cdr
member
lii2 lil
setq
lil
append
lil1
list
list
car
lii1
car
lii2
mapcar
function
reverse
lil2
list
list
cadr
lii1
cadr
lii2
lil3
setq
pln
append
mapcar
function
car
lil
list
cadr
last
lil
setq
d
apply
function
mapcar
function
lambda
a b
distance
a b
pln
cdr
pln
entmake
append
list
0
"LWPOLYLINE"
100
"AcDbEntity"
100
"AcDbPolyline"
cons
90
length
pln
cons
70
getvar
'plinegen
128
38
0.0
mapcar
function
lambda
x
cons
10
x
pln
list
210
0.0
0.0
1.0
62
1
prompt
\n
Distance : "
princ
rtos
d
2
50
prompt
\n
Elapsed time : "
princ
rtos
car
_vl-times
ti
1000.0
2
50
prompt
" seconds..."
princ
Regards, M.R.
Last Edit: January 04, 2019, 09:51:39 AM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
ahsattarian
Newt
Reply #16 on:
December 16, 2020, 01:54:59 AM »
This Helps U :
[Select]
defun
c:tsp
setq
ss
ssget
0
"point"
cond
sslength
ss
2
exit
setq
li1
nil
setq
li2
nil
setq
k
1
setq
n
sslength
ss
repeat
n
setq
k
1+
k
setq
s
ssname
ss k
setq
en
entget
s
setq
po
cdr
assoc
10
en
if
k
3
setq
li1
append
list
po
li1
setq
li2
append
list
po
li2
foreach
po li2
setq
lii
nil
setq
k
1
setq
n
length
li1
repeat
n
setq
k
1+
k
setq
po1
nth
k li1
if
k
1-
length
li1
setq
po2
nth
1+
k
li1
progn
setq
po1
nth
0
li1
setq
po2
nth
1-
length
li1
li1
setq
lii
append
list
list
po1 po po2
lii
setq
dili
nil
foreach
a lii
setq
po1
nth
0
a
setq
po2
nth
1
a
setq
po3
nth
2
a
setq
d12
distance
po1 po2
setq
d23
distance
po2 po3
setq
d13
distance
po1 po3
setq
di
d12 d23
d13
setq
dili
append
list
di
dili
setq
dimin
apply
min
dili
setq
k
0
while
k
length
dili
cond
dimin
nth
k dili
setq
i k
setq
k
length
dili
setq
k
1+
k
setq
li3
nil
setq
ii
1+
i
if
ii
length
li1
progn
setq
k
0
setq
flag
0
while
k
length
li1
if
and
k ii
flag
0
progn
setq
li3
append
list
po
li3
setq
flag
1
progn
setq
li3
append
list
nth
k li1
li3
setq
k
1+
k
setq
li3
append
list
po
li1
setq
li1 li3
command
"pline"
foreach
po li1
command
po
command
"close"
princ
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
