Author Topic: Lisp for a Roof Cricket  (Read 2744 times)
nickbs
« on: October 29, 2018, 08:42:37 AM »
Hello, has anyone made a lisp to layout a simple roof cricket? IF not I would like to start to make one.
Any help would be appreciated.
Krushert
  • FREE BEER Tomorrow!!
Re: Lisp for a Roof Cricket
« Reply #1 on: October 29, 2018, 10:03:24 AM »
Cricket?  Or A saddle?  There is a difference.
I have been meaning to create one but I have no time.  And it would not be for me actually because I am doing construction administration for Roofing Program for a national client and hence have no time.   It would be for my architect and designers that draw up the plans.  It kills me see them drawing it out when I know it can be automated.
« Last Edit: October 29, 2018, 10:25:13 AM by Krushert »
« Reply #2 on: October 29, 2018, 10:05:31 AM »
First start by giving an example DWG of what you want to create.
Attached is a crude Hip truss program I did in 2003.It creates a 2D plan view of a hip truss assembly with single lines drawn on the current layer.
nickbs
« Reply #3 on: October 29, 2018, 12:21:33 PM »
Hello,, attached is a rough draft. I'm limited on time right now too.
nickbs
« Reply #4 on: October 29, 2018, 01:53:51 PM »
I added a little more detail to the print.  :idea:
« Reply #5 on: October 29, 2018, 02:02:43 PM »
I assume you are drawing this in 2D.
User would need to input pitch of main roof, pitch of cricket.
Rafter size (2x6)
Rafter spacing 16-24
Ridge board size
Ridge height above main roof end point or ridge run distance.
Bevel cut or butt at the rafter to roof plane joint.
Given this info I think you could draw the needed parts.
Krushert
« Reply #6 on: October 29, 2018, 02:07:09 PM »
Ahhh we call those dormers.    :-D
I thought you were talking about drainage saddles and crickets for flat roofs.
nickbs
« Reply #7 on: October 29, 2018, 02:30:11 PM »
No not for flat roofs.. that is another topic... I'm designing a couple different Hotel Hiltons. We could talk about flat roof venting all day.. and emergency roof drains.
I send out the poly iso cricket designs to another company. But thanks.  8-)
