Author Topic: Print an Excel Spreadsheet with White Background  (Read 4606 times)
Fabricio28
« on: October 24, 2018, 07:24:57 AM »
Hi guys
I'm trouble to plot excel table from auto cad.
In the model space it is plotting fine, background white and the text is black.👍
But when I'm plotting at the paper space, using viewport the background is black.
I don't know what to do to fix it.
Anybody could help me, please?
Fabrício
« Last Edit: October 24, 2018, 07:46:08 AM by Fabricio28 »
sljohnson
Re: Print an Excel Spreadsheet with White Background
« Reply #1 on: October 24, 2018, 01:25:51 PM »
Uncheck "Plot Transparency" in the Plot Options of the plot dialog window.
Fabricio28
« Reply #2 on: October 24, 2018, 01:40:14 PM »
Thank for replay
But it isn't working.
I took a picture of the Excel Spreadsheet with Black Background.
I don't konw how but the excel spreadsheet bellow is white.
« Reply #3 on: October 24, 2018, 03:04:01 PM »
Try to change the ole plot quality to 'Monochrome'.
Fabricio28
« Reply #4 on: October 24, 2018, 03:06:42 PM »
Hi my old friend Ron,
The OLE plot quality is already monochrome.
Fabricio28
« Reply #5 on: October 24, 2018, 03:26:49 PM »
The layout model seems to be ok!
I don't know what's wrong.
Fabrício
Willie
  • Going nowhere slowly
« Reply #6 on: October 25, 2018, 05:55:04 AM »
Have you tried to plot a pdf?
Are there a white fill in the excel sheet?  Or are the cells set to "No Color" fill.
and, set the OLE object to High Quality.
Fabricio28
« Reply #7 on: October 25, 2018, 07:17:31 AM »
Hi Willie
How are you?
I've already tried to plot to a pdf with the same ctb file, and worked Fine.
The excel sheet is set to " No Color" fill. And I've tried to change to plot quality to "High graphics".
I've inserted the excel sheet several times.
I don't know what to do.  :crazy2:
Fabricio28
« Reply #8 on: October 25, 2018, 09:36:38 AM »
Guys
I had to inserted the excel sheet over to layout model, not using viewport.
And worked Fine!
If anyone has a better solution to plot using viewport, it will be very wellcome.
Because I don't like using excel sheet from layout model. I would rather to model space.  :-D
« Reply #9 on: October 25, 2018, 11:42:30 AM »
have you tried actually importing the table through a link, instead of as an OLE object?
Fabricio28
« Reply #10 on: October 25, 2018, 01:39:34 PM »
Hello mjfarrell
I don't like import as auto cad table, I would rather excel sheet.
I've always pasted especial with a link, it always worked fine for me.
I don't understand what it is worng now.
Fabrício
