(IF (SETQ ARQKEY (FINDFILE "GOOGLEKEY.TXT"))
(ALERT "file GOOGLEKEY.TXT OK.")
(ALERT "File GOOGLEKEY.TXT not found!")
(IF ARQKEY
(PROGN
(SETQ ARQ (OPEN ARQKEY "r")) (SETQ MYKEY (READ-LINE ARQ)) (CLOSE ARQ)
(setq MYSTR (STRCAT "https://maps.googleapis.com/maps/api/staticmap"
"?center=-22.876012,-42.445214"
"&size=400x400"
"&scale=1"
"&zoom=18"
"&format=jpg"
"&maptype=satellite"
"&key=" MYKEY))
(SETQ MYIMG (vl-filename-mktemp "MYIMG" (GETVAR "TEMPPREFIX") ".jpg"))
(SETQ MYARQ (vk_DownloadFile MYSTR MYIMG))
(IF MYARQ (ALERT MYARQ))
(PRINC)
Yes, with your help, Vovka, it was easy.
The next step, the most important is to insert the image.
The conversion of geographic coordinates to UTM does not have to, since I have some guidelines for this.
What I really need are: scale, angle of rotation and the insertion point because a center point is passed and the image is inserted in the lower left corner.
I also know that the size and zoom will also interfere but I can see later maybe.
Can you help me with these Vovka too?
