(Maybe that's not that big stuff, but if someone has already a solution it would be fine.)
Semi - solved: see below
I have a UCS called "myUCS"; it is a moved and (z-)rotated WCS; z-axis is still going "to the top" (upwards, to the zenith)
This UCS is a kind of "Top-view" UCS, now I need the sub-ucs (derivated) UCS like
- view from left
- view from right
- ...front
- ...back
So I "only" need to modify the DXF-codes 10(?), 11 and 12 - replace value A with negative value B and so on.
But nevertheless - if somebody has a code snippet it would be great.
Thanks!
Edit / Solution:
here are the GC-codes for these UCS. You can see the changing of GC11 and GC12
top
(10 0.0 0.0 0.0) (11 1.0 0.0 0.0) (12 0.0 1.0 0.0) (79 . 0) (146 . 0.0))
front
(10 0.0 0.0 0.0) (11 1.0 0.0 0.0) (12 0.0 0 1.0) (79 . 0) (146 . 0.0))
left
(10 0.0 0.0 0.0) (11 0 -1.0 0) (12 0.0 0 1.0) (79 . 0) (146 . 0.0))
back
(10 0.0 0.0 0.0) (11 -1.0 0 0) (12 0.0 0 1.0) (79 . 0) (146 . 0.0))
right
(10 0.0 0.0 0.0) (11 0 1.0 0.0) (12 0 0.0 1.0) (79 . 0) (146 . 0.0))
