Author Topic: Merging Object Data Tables  (Read 4731 times)
MSTG007
« on: October 03, 2018, 12:25:05 PM »
Does anyone know how to merge 2 or more object tables with all objects to a new single object data table?
Civil3D 2020
Re: Merging Object Data Tables
« Reply #1 on: October 03, 2018, 01:35:03 PM »
try a join....
MSTG007
« Reply #2 on: October 03, 2018, 02:13:27 PM »
Thanks. I will have to check that out. Is that basically where I can select what objects I want to join to I'm guessing.
Civil3D 2020
« Reply #3 on: October 03, 2018, 02:19:33 PM »
Uh its joining two databases on a data key....(probably wrong term)
MSTG007
« Reply #4 on: October 03, 2018, 02:28:42 PM »
This is what I'm looking at. Would like to join all the features on the first capture with the second.
I do not have a database connected to my drawing. These entities where from the mapimport command and I attached the Object Data to them.
I just thought I would ask if it wasn't hard to do.
Civil3D 2020
« Reply #5 on: October 03, 2018, 02:29:48 PM »
you will need to bring the data in through the mapwspace
« Reply #6 on: October 03, 2018, 03:03:12 PM »
or, you open the data tables...and just merge them outside of map
MSTG007
« Reply #7 on: October 04, 2018, 07:07:27 AM »
that's kinda what I did this morning. Thanks for pointing me that direction.
Civil3D 2020
