Author Topic: MgdDbg 2019  (Read 5153 times)
Jeff H
MgdDbg 2019
« on: September 28, 2018, 11:51:41 PM »
Had to update MgdDbg since they remove some classes in 2019 and causes an error when loading and looks like Autodesk has not updated it on Github.
Attached is a bundle that contains 2013,2015, & 2019
The solution is in  MgdDbg.bundle\Contents\src\MgdDbg
The actual dll's are at MgdDbg.bundle\Contents\bin\v23.0\Release for 2019.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: MgdDbg 2019
« Reply #1 on: September 29, 2018, 03:08:33 AM »
Kudos !
Called Kerry in my other life
I live at UTC + 13.00
Jeff H
Re: MgdDbg 2019
« Reply #2 on: September 29, 2018, 05:22:32 PM »
huiz
  • Certified Prof C3D
Re: MgdDbg 2019
« Reply #3 on: October 01, 2018, 03:21:48 AM »
Great! Last years I built them myself. I'll have a look on your variant, since Autodesk removes stuff I used a lot of #if's to exclude non-working code.
But I can't live without this tool, it is a great help to examin the drawing and entities. I used a lot of Entity Data lately and it is really easy with this tool to see if it was added correctly.
mohnston
  • CAD Programmer
Re: MgdDbg 2019
« Reply #4 on: October 24, 2018, 12:09:55 PM »
Much appreciated.
CAD Programming Solutions
Bryco
Re: MgdDbg 2019
« Reply #5 on: October 24, 2018, 01:25:17 PM »
Hi Jeff I am getting
Couldn't process file Snoop\Forms\Objects.resx due to its being in the Internet or Restricted zone
Do I have to download some files?   I have unblocked the files
Bryco
Re: MgdDbg 2019
« Reply #6 on: October 24, 2018, 01:51:23 PM »
No problem I didnt realize I had to unblock every file.  Thanks Jeff
Jeff H
Re: MgdDbg 2019
« Reply #7 on: October 25, 2018, 07:05:37 PM »
I think if you unblock before you unzip then it will unblock all
Bryco
Re: MgdDbg 2019
« Reply #8 on: October 26, 2018, 07:22:58 PM »
Great I just tried it and it worked thanks
