I have this snippet code
'((0 . "INSERT")
(66 . 1)
(2 . "TBLK_ATT_CTL")
) ;; end SSGET
)(command "._ddatte" att1
"");;start attribute edit
that for some reason launches the Edit Attribute dialog box extra large. It does this on my puter only. Not any one else's.
This snippet is a small portion of a larger code. To test, I copied just this bit out and ran it separately. It still launches the dialog box large.
It resizes once you move the dialog box, but only then.
J. Logan
ACAD 2015
