I have made a table using the table command in autocad 2007, no problem there. The problem is when I try to paste special my excel document into Autocad it pretty much forgets all the formatting I originally did in my table. The text is super small and the cells are not the correct size. I have messed around in excel removing the formatting there and bringing it in to autocad that way, it helps but is still needs alot of work to make it look right. Does anyone have any ideas of what I could be missing? Some setting I have not changed in autocad? Thanks for any thoughts.
