Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Creating Windows Shortcuts has stopped working
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Creating Windows Shortcuts has stopped working (Read 1120 times)
BazzaCAD
Guest
on:
September 14, 2018, 06:21:12 PM »
I've used the code below to create Windows Shortcuts to network folders for years, but for some reason over the last few days it has shopped working for everyone in the office.
All I can think of is a Windows Update has broke something.
Anyone have any ideas?
Code - Auto/Visual Lisp:
[Select]
defun
CreateShortcut
Name favFldr Path
if
wshLibImport
nil
progn
vlax-import-type-library
:tlb-filename
strcat
dos_specialdir
37
"wshom.ocx"
;_ "c:\\windows\\system32\\wshom.ocx"
:methods-prefix
"wshm-"
:properties-prefix
"wshp-"
:constants-prefix
"wshk-"
setq
wshLibImport T
setq
wshShell
vlax-create-object
"WScript.Shell"
setq
shrtObj
wshm
CreateShortcut wshShell
strcat
favFldr
Name
".lnk"
vlax-put-property
shrtObj 'IconLocation
strcat
MasterServerPath
"startup
Icons
Acad.ico"
vlax-put-property
shrtObj 'TargetPath Path
vlax-invoke-method
shrtObj 'Save
The .lnk file is created, but when you double click on it, nothing happens. If I call the .lnk file from the command line, I get "The data is invalid" message box & "Access is denied" at the command line...
Last Edit: September 14, 2018, 06:24:33 PM by BazzaCAD
Logged
cmwade77
Swamp Rat
Re: Creating Windows Shortcuts has stopped working
Reply #1 on:
September 14, 2018, 07:04:04 PM »
The access denied would indicate that it is a security/permissions issue that is preventing you from saving to that location. My suggestion is to check with your IT department to see if they changed something recently.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
