I find this code but is not working on meters . Can any one change the code to suport this
Vx = 1000 * x / scale , and Vy = 1000 * y / scale
I think the problem is here
(setq vpxd
(* sf
(abs (- (car vpc2
) (car vpc1
))))) ; Determine horizontal length of selected window (setq vpyd
(* sf
(abs (- (cadr vpc2
) (cadr vpc1
))))) ; Determine vertical height of selected window
(defun c:igalvp
(/ vpl vplyes l0 ln layers cp cl cs ofs vpc1 vpc2 vpxd vpyd vpc svpc ssvp ssvp1 sf lpno vpno ssnum vpent nvpc1 nvpc2 nvpc1x nvpc1y nvpc2x nvpc2y
) ; Creates layout of Paper Space viewports of specified 2D orthagonal views from Model Space
; Used when all 2D design is done in Model Space at full scale and all dimensioning is done in Paper Space as associated scale
; Start command from destination layout tab
; Program will switch to Model Space for selection of desired objects
; Program will return to layout tab for creation of viewport frames
; First a single viewport is made that includes all relevant views of desired part at the desired zoom level
; The single viewport is copied over itself the number of desired separate views
; Then the overlaying viewports are individually clipped to the edges of the separate views
; The separate views will maintain their original orientation and alignment
; The separate views can be rectangular by specifying opposite corners or circular by specifying a center and radius
; Afterwards move the individual views orthogonally, if needed, to allow space for dimensions
(setvar "cmdecho" 0) ; Turn off command line echoing (setq cp
(getvar "ctab")) ; Store current tab name (setq cl
(getvar "clayer")) ; Store current layer name (setq cs
(getvar "osmode")) ; Store current osnap mode (setq vpl
"TPZ-VPort") ; ==>> Assume using Viewport layer for viewport frames, change code value here if needed <> Set viewport border offset from actual detail, change code value here if needed <<== (setvar "osmode" 0) ; Turn osnap on (if (/= cp
"Model") ; Must be started from a layout tab to establish destination, quit quietly if on Model tab (princ "\n") ; Clean up command line (setq vplyes
0) ; Assume viewport doesn't exist (setq l0
(tblnext "LAYER" 1)) ; Get past 0 layer in layer list (setq ln
(cdr (assoc 2 layers
))) ; Extract layer name from list )
(if (= vplyes
0) (command "layer" "NEW" vpl
"COLOR" "7" vpl
"")) ; Make viewport layer and assign color to magenta if doesn't exist (setvar "clayer" vpl
) ; Change to viewport layer (command "layer" "ON" (strcat "0," vpl
) "UNLOCK" (strcat "0," vpl
) "") ; Turn on and unlock viewport and 0 layer (command "zoom" "e") ; View entire layout tab (setvar "ctab" "Model") ; Activate Model tab (command "zoom" "e") ; View entire Model Space area (setq vpc1
(getpoint "\nSpecify first corner of model space window area: ")) ; Just pick rough area including all relavent details, will fine-tune border area later in Paper Space (if vpc1
; Quietly quit if no point specified (setq vpc2
(getcorner vpc1
"\nSpecify opposite corner of model space window area: ")) ; Window rectangle can be designated in any direction (if vpc2
; Quietly quit if no point specified (princ "\n") ; Clean up command line (setvar "ctab" cp
) ; Return to layout tab program was started from (command "pspace") ; Switch to Paper Space of layout tab (setq svpc
(getpoint "\nSpecify destination of paper space viewport center: ")) ; Can't change layout tabs manually here (if svpc
; Quietly quit if no point specified (setq sf
(getreal "\nViewport zoom scale factor : ")) ; Default to full-scale if no value is inputted (if (= sf
nil) (setq sf
1.0) (setq sf
(abs sf
))) ; Make sure scale factor is positive number (setq vpxd
(* sf
(abs (- (car vpc2
) (car vpc1
(* sf
(abs (- (cadr vpc2
) (cadr vpc1
))))) ; Determine vertical height of selected window (setq vpc
(list (/ (+ (car vpc1
) (car vpc2
)) 2.0) (/ (+ (cadr vpc1
) (cadr vpc2
)) 2.0) 0.0)) ; Determine center point of selected model window (setq ssvp
(ssget "L")) ; Start selection set with last viewport frame (setq ssvp1
(ssget "L")) ; Another copy of viewport frame selection set (command "mspace") ; Open viewport window to Model Space (command "ucsicon" "ON") ; Turn on UCS icon for viewport (command "ucs" "WORLD") ; Reset UCS to WCS (command "zoom" "C" vpc
(rtos vpyd
)) ; Center view of viewport window using determined point (command "vports" "LOCK" "ON" ssvp
"") ; Lock scale and position of model in viewport (command "pspace") ; Close viewport window (command "zoom" (list (- (car svpc
) (/ vpxd
2.0)) (- (cadr svpc
) (/ vpyd
2.0))) (strcat "@" (rtos vpxd
) "," (rtos vpyd
))) ; Zoom in on just created viewport extremes (command "zoom" "0.95X") ; Back zoom off slightly to see edges clearly (setq lpno
2) ; Loop counter for making separate viewports (setq vpno
(getint "\nNumber of separate viewports to make from this viewport : ")) ; Will divide single viewport into separate viewports for othagonal views of 2D part (if (>= vpno
2) ; Proceed to copy current viewport if 2 or more separate viewports desired (while (<= lpno vpno
) ; Check if viewport loop counter less than number of viewports desired (command "copy" ssvp
"" "0,0" "@0,0") ; Make copy of new viewport laying exactly on top of first viewport (setq lpno
(1+ lpno
)) ; Increment viewport loop counter (ssadd (entlast) ssvp1
) ; Add viewport copy to selection set )
(setq ssnum
0) ; Loop counter for fine-tuning separate viewports (while (= vpno
2) ; Check for multiple viewports (setq clt
(strcat " #" (rtos (+ ssnum
1) 2 0))) ; Make command prompt string if using multiple viewports (setq clt
"") ; Make command prompt string if using single viewport )
(initget 128) ; Enable string responses from point prompt (setq nvpc1
(getpoint (strcat "\nSpecify first corner of viewport" clt
" window area or [Center point of circle]: "))) ; Pick actual part corner, program will apply offset (if nvpc1
; Will repeat asking for first corner if none specified (if (= 'STR
(type nvpc1
)) ; Check if string was inputted instead of corner point (if (= "C" (strcase (substr nvpc1
1 1))) ; Check if asking for circular viewport area (setq nvpc1
(getpoint (strcat "\nSpecify center of viewport" clt
" window area: "))) ; Pick center of separate circular viewport window (if nvpc1
; Will return to asking for first corner if center not specified (setvar "osmode" 0) ; Turn osnap off (princ (strcat "\nSpecify radius of viewport" clt
" window area: ")) ; Make command prompt for circle viewport (command "circle" nvpc1 pause
) ; Make circle to clip existing viewport (setvar "osmode" 2559) ; Turn osnap on (command "vpclip" vpent ssvp
) ; Clip existing viewport to circle (setq ssnum
(1+ ssnum
)) ; Increment fine-tuned viewport loop counter )
(setq nvpc2
(getcorner nvpc1
(strcat "\nSpecify opposite corner of viewport" clt
" window area: "))) ; Window rectangle can be designated in any direction, pick actual part corner, program will apply offset (if nvpc2
; Will repeat asking for first corner if none specified (setq nvpc1x
(car nvpc1
)) ; Find X portion of first corner (setq nvpc1y
(cadr nvpc1
)) ; Find Y portion of first corner (setq nvpc2x
(car nvpc2
)) ; Find X portion of second corner (setq nvpc2y
(cadr nvpc2
)) ; Find Y portion of second corner (if (> nvpc2x nvpc1x
) ; Determine horizontal direction of viewport window rectangle (setq nvpc2x
(+ nvpc2x ofs
)) ; Add horizontal offset to right of specified left-to-right window rectangle (setq nvpc1x
(- nvpc1x ofs
)) ; Add horizontal offset to left of specified left-to-right window rectangle )
(setq nvpc2x
(- nvpc2x ofs
)) ; Add horizontal offset to left of specified right-to-left window rectangle (setq nvpc1x
(+ nvpc1x ofs
)) ; Add horizontal offset to right of specified right-to-left window rectangle )
(if (> nvpc2y nvpc1y
) ; Determine vertical direction of viewport window rectangle (setq nvpc2y
(+ nvpc2y ofs
)) ; Add vertical offset to top of specified lower-to-upper window rectangle (setq nvpc1y
(- nvpc1y ofs
)) ; Add vertical offset to bottom of specified lower-to-upper window rectangle )
(setq nvpc2y
(- nvpc2y ofs
)) ; Add vertical offset to bottom of specified upper-to-lower window rectangle (setq nvpc1y
(+ nvpc1y ofs
)) ; Add vertical offset to top of specified upper-to-lower window rectangle )
(setvar "osmode" 0) ; Turn osnap off (command "rectang" (list nvpc1x nvpc1y
) (list nvpc2x nvpc2y
)) ; Make rectangle with offset to clip existing viewport (setvar "osmode" 2559) ; Turn osnap on (setq ssvp
(ssget "L")) ; Select last rectange (command "vpclip" vpent ssvp
) ; Clip existing viewport to rectangle (setq ssnum
(1+ ssnum
(princ "\nThis command must be started from a layout sheet!") ; Need to start on a layout tab so program knows where to create the new viewports )
(setvar "ctab" cp
) ; Reset to stored tab name (setvar "clayer" cl
) ; Reset to stored layer name (setvar "osmode" cs
) ; Reset to stored osnap mode (setvar "cmdecho" 1) ; Turn on command line echoing (princ) ; Clean up and exit )
