Author Topic: Real quick fix  (Read 5076 times)
rugaroo
  • The Other CAD Guy
Real quick fix
« on: January 07, 2004, 04:52:57 PM »
I am running into a prob here and need to get this to work quickly...any ideas as to whats wrong.
(DEFUN c:3dpad ()
  (SETQ cmd (GETVAR "CMDECHO")
osm (GETVAR "OSMODE")
ort (GETVAR "ORTHOMODE")
lay (GETVAR "CLAYER")
  (SETVAR "CMDECHO" 0)
  (SETQ cen (GETPOINT "\nPick point in center of lot: ")
elv (GETREAL "\nPad elevation: ")
  (COMMAND "._bpoly" cen "")
  (SETQ old (ENTGET (ENTLAST)))
  (COMMAND "offset" "0.50" (ENTGET (ENTLAST)) cen "")
  (VL-CMDF "ERASE" old "")
  (VL-CMDF ".-CHANGE" (ENTGET (ENTLAST)) "" "P" "E" elv "")
  (PRINC "PLEASE CONTINUE ONTO NEXT LOT...")
  (PRINC)
THX - Rug
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
daron
Real quick fix
« Reply #1 on: January 07, 2004, 05:18:33 PM »
How's that:
(DEFUN c:3dpad ()
     (COMMAND "._boundary" cen "")
     (SETQ old (ENTLAST))
     (COMMAND "offset" "0.50" old cen "")
     (PRINC)
there is no bpoly command. Entget was too far for offset command.
rugaroo
  • The Other CAD Guy
Real quick fix
« Reply #2 on: January 07, 2004, 05:31:01 PM »
Ok...for some reason after the offset, for some reason it is crashing. It displays the ent name, but pauses, and then say all the rest are invalid commands
Real quick fix
« Reply #3 on: January 07, 2004, 05:39:02 PM »
Maybe not for you. :D
To create the boundaries
Open the map drawing or query the map data into the project.
Create the boundaries as closed 2-dimensional polylines on a separate layer.
Use one of these methods to create the 2-D polylines:
PLINE command. See the pull-down Help menu.
BOUNDARY (BPOLY) command
MAPCLPLINE command
All polylines you create must be closed. You can also create boundaries by querying in polylines from other drawings.
Create and attach object data to the boundaries.
See Create the Boundary Object Data Table. The object data uniquely identifies the boundaries.
After attaching object data, create a separate drawing for the boundaries. To create the map sheet boundary drawing, do the following:
At the command line, enter WBLOCK.
In the Write Block dialog box, enter a file name and click OK.
At the Block name prompt, press ENTER without entering a block name.
For the Insertion base point, enter 0,0.
Select the boundaries.
When prompted to include Autodesk Map information, choose No.
The boundaries are saved as a separate drawing. If you attach object data at a later date, use WBLOCK again to update the map sheet boundary drawing with the object data.
- Rug
To draw parcels, use the line and curve commands in the Lines/Curves menu. You can also use either the PLINE command, or any AutoCAD line or curve command.
NOTE  Do not use spiral curves in the parcel geometry because incorrect parcel areas are calculated. If you want to create a parcel from a spiral, then use the BPOLY command to convert the spiral into a polyline before defining the parcel.
After you draw the parcel geometry, you must define the parcels to the parcel database. For more information, see Defining Parcels.
NOTE  Be sure to draw the parcels as closed regions. If any of the joining lines has a break, then you cannot define the parcels.
Real quick fix
« Reply #4 on: January 07, 2004, 06:23:04 PM »
One word of caution, in any version of AutoCAD prior to 2004, whenever you query the drawing for (ENTLAST) sometimes it will not return the LAST entity if it is not visible on the screen.
daron
Real quick fix
« Reply #5 on: January 07, 2004, 06:31:09 PM »
Sorry Mark. I get a dialog when running bpoly. To avoid this there is no (command "._bpoly"...) but rather (command ".boundary"...). I meant bpoly was a bad idea for use in lisp. As far as the offset problem goes, make sure the arguments in the command line equal that of what is in the code.
SMadsen
Real quick fix
« Reply #6 on: January 07, 2004, 06:37:24 PM »
Gotta say, it's the first time I ever saw someone use (entget (entlast)) explicitly to pass entities to a COMMAND function. :)
Didn't you guys get errors from that?
Real quick fix
« Reply #7 on: January 07, 2004, 10:10:29 PM »
Nope, but you could also use "Last" or "L" as the command option.
SMadsen
Real quick fix
« Reply #8 on: January 08, 2004, 04:40:43 AM »
Nope?
(defun crashy ()
(setq ent (car (entsel))
      p1  (getpoint "\nFrom: ")
      p2  (getpoint "\nTo: ")
(and ent p1 p2 (vl-cmdf "MOVE" (entget ent) "" p1 p2)))
daron
Real quick fix
« Reply #9 on: January 08, 2004, 09:34:59 AM »
Yes, I did that's why I took it out in the first instance of it. I didn't consider the second instance of it and hoped that Rug could catch that one on his own. BTW, Rug, what's with combining command and vl-cmdf all in one routine? They both perform the same feat, just in different ways.
Stig, I once saw a guy take a selected object to an entity list, then revert it back. It was a very odd thing. Of course this person collected a bunch of variables that he didn't even use in the routine.
SMadsen
Real quick fix
« Reply #10 on: January 08, 2004, 10:48:39 AM »
Most built-in commands accept the list returned by ENTSEL but I never heard they could handle entity lists. Didn't mean to sound condescending, just surprised by the approach.
Daron, I bet we've all been where you describe. I still drag some pretty weird routines along with an .mnl that I wrote 14 years ago. Do I ever think about correcting it? Sure. Do I ever get around to do it? Nah...
daron
Real quick fix
« Reply #11 on: January 08, 2004, 10:59:42 AM »
Yeah.
