Author Topic: Autodesk Map - Cookie Cut out from Master Drawing  (Read 3462 times)
MSTG007
« on: September 05, 2018, 10:15:44 PM »
Here’s the scenario. I have a large state wide dwg that has interstates, highways, roads, rivers, lakes and towns, etc. All entities are on their corresponding layers. I would like know if MAP can select a county line boundary and clip all information out into its own dwg. County name dwg. I know it sounds simple. However the road lines are from the TIGER GIS and are polylines with object data and property sets.
Can this be done and are the steps simple?
Thanks for a direction.
Civil3D 2020
huiz
  • Certified Prof C3D
Re: Autodesk Map - Cookie Cut out from Master Drawing
« Reply #1 on: September 06, 2018, 03:33:34 AM »
I thought you can query a connected drawing and bound it by a boundary.
This might be an interesting source to view how it works: https://www.youtube.com/watch?v=9Sxl1utUIL0
« Reply #2 on: September 06, 2018, 10:44:34 AM »
You can
it would need to be
A insert the boundary SHP file as polygon(s)
THEN
Attach drawing with all the other stuff to Display Manager tab
and clip the attached using boundary created by the first operation
MSTG007
« Reply #3 on: September 06, 2018, 12:35:21 PM »
Ok Gotcha.
I also just thought about doing maptrim and seems to work as well.
Civil3D 2020
