Author Topic: AutoCAD Map - Assign Object Data from Points to another entity  (Read 3947 times)
MSTG007
« on: September 04, 2018, 07:21:24 AM »
Just a general question. Is it possible when using MAPIMPORT. To have the object data that you are importing be to a line or arc opposed to a block / attributed block or point?
Civil3D 2020
Re: AutoCAD Map - Assign Object Data from Points to another entity
« Reply #1 on: September 04, 2018, 12:16:58 PM »
uh....looks like NO
As it works...unless the object data is already assigned, or the data table linked...you get whatever is in the source
Rod
« Reply #2 on: September 04, 2018, 07:47:18 PM »
I think you can create object data on a closed polyline from text or block attribute data where the text or block is inside the polyline.
You use "generate data links" or adegenlink.
Otherwise use a free GIS program like QGIS and look into a "spatial join". This will allow you to join data from one object type to another in the same location
"All models are wrong, some models are useful" - George Box
MSTG007
« Reply #3 on: September 04, 2018, 08:17:26 PM »
That makes sense Rod.
Civil3D 2020
« Reply #4 on: September 05, 2018, 09:53:52 AM »
yes, however it isn't happening within the context of MAPIMPORT
That is the method for taking data associated with a polygon, and applying it to the objects.
MSTG007
« Reply #5 on: September 05, 2018, 10:35:48 AM »
Interesting... There why is it sometimes hard to find a workflow to do something basic?
Civil3D 2020
« Reply #6 on: September 05, 2018, 02:04:28 PM »
MAP  is a second thought, or third to  Autodesk, they basically starve this application for development resources.
