Author Topic: The BeginQuit event  (Read 4243 times)
Amsterdammed
The BeginQuit event
« on: June 05, 2005, 08:01:31 AM »
Morning Folks,
I’m desperately trying to get into VBA as quick as possible, so I’m not depending on my lisp skills only.
I need to understand how the “BeginQuit” Handler works, since I write a VBA program that must start when acad quits.
Anybody out there who can help??
Bernd
Dnereb
The BeginQuit event
« Reply #1 on: June 11, 2005, 07:01:09 AM »
Hi , Bernd
I suppose you mean the BeginClose event for a document.
"BeginQuit" is not availeble in vba
If you open the VBA IDE (left Alt-F11)
you'll see ThisDrawing in your project browser. double click it and place this code:
Option Explicit
Private Sub AcadDocument_BeginClose()
'do your stuff
End Sub
This will fire just before the document is closed. Acad itself will remain running.
Amsterdammed
The BeginQuit event
« Reply #2 on: June 14, 2005, 08:45:40 AM »
I'm searching for a event that fires when Acad is shut down. End of the day, drafter goes home and has to fill in a form.
Are you sure there is no VBA event for? I know that there is no vlisp event for in A2002, in 2006 it works with the command reactor for quit, but in my company we change only next year, so i need something for A2002.
Bernd
The BeginQuit event
« Reply #3 on: June 14, 2005, 01:26:50 PM »
Quote from: Decent
Decent & Bernd, for both of your benefit here is a snip from the VBA Developer Reference in R2002
Quote from: AcadHelp
BeginQuit Event
Triggered just before an AutoCAD session ends or a document closes.
See Also | Example
Signature
object.BeginQuit (Cancel)
object
Application
An object expression that evaluates to a valid container object. In this case, the only valid container is the application.
Cancel
Boolean; output from the handler
TRUE: Aborts the shutdown of AutoCAD.
FALSE: Allows the shutdown of AutoCAD to continue.
Remarks
The BeginQuit event marks the end of the AutoCAD session.
Amsterdammed
The BeginQuit event
« Reply #4 on: June 15, 2005, 09:18:14 AM »
:D Jeff, you saved my ass.
Thanks a lot, that approach works.
