Author Topic: Block name entity Anonymous?  (Read 5057 times)
dubb
« on: August 27, 2018, 07:36:54 PM »
I'm not sure how to phrase this question.
When I am listing the entity properties for a certain block. using
(assoc 2 (entget(car(entsel)))) I get
(2 . "*U237") I am trying to obtain the block name. But I think this is the anonymous name?
How do always get the block name. I am writing a script to give me a list of block names for an entire selection set.
Crank
Re: Block name entity Anonymous?
« Reply #1 on: August 28, 2018, 02:15:36 AM »
If it's a real anonymous block, then "*U237" is the block name.
If it's a dynamic or parametric block then you need the effective name.
tombu
  • ByLayer=>Not0
« Reply #2 on: August 28, 2018, 07:23:08 AM »
I use UnAnon.Lsp by David Bethel for renaming an anonymous block.  It's on his free lisp page: http://www.davidbethel.com/lisp/
Tom Beauford P.S.M.
dubb
« Reply #3 on: August 28, 2018, 03:48:57 PM »
Thanks, I wonder why they make it more complicated.
dgorsman
« Reply #4 on: August 29, 2018, 09:59:01 AM »
Because it needs to be.  If the block name wasn't unique, then changing one dynamic property would chance the properties of *all* instances of that block.  While that may be desirable in some circumstances it would really neuter features like having one block definition with multiple visibility states.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
dubb
« Reply #5 on: August 29, 2018, 11:35:16 AM »
aH..That makes sense.
dubb
« Reply #6 on: August 29, 2018, 11:41:06 AM »
Thanks to your explanation, I found out if I resetted all of my dynamic blocks, then generated a list of blocks, I didn't get anonymous block names.
« Reply #7 on: August 29, 2018, 12:33:39 PM »
This is not necessary - did you read the content of the link provided by Crank?
dubb
« Reply #8 on: August 29, 2018, 01:09:53 PM »
I reread that, and I think I'll try implementing that method into my block listing script.
ahsattarian
« Reply #9 on: January 01, 2021, 08:30:58 AM »
Would u please offer the lisp here   ????
The link doesn't work for me   !!!!
hmspe
« Reply #10 on: January 01, 2021, 08:53:14 AM »
@ahsattarian:
Try an interner search for "UnAnon.lsp".  The code is posted on several sites.
"Science is the belief in the ignorance of experts." - Richard Feynman
Dlanor
« Reply #11 on: January 01, 2021, 09:30:20 AM »
Unanon.lsp will probably need updating as IIRC it has an error routine that contains command call(s). This will cause an error in AutoCAD 2015 and later.
elyosua
  • Mosquito
« Reply #12 on: March 19, 2021, 02:14:07 PM »
Yo tuve este problema y lo solucioné borrando el bloque anónimo y después insertándolo pero eligiendo el nombre verdadero del bloque.
I had this problem and I solved it by deleting the anonymous block and then inserting it but choosing the true name of the block.
« Last Edit: March 19, 2021, 02:18:55 PM by elyosua »
tombu
  • ByLayer=>Not0
« Reply #13 on: March 19, 2021, 03:04:05 PM »
I believe I updated the attached version to use command-s in 2016. Don't need it often but always saved me when I needed it.
David Bethel thanks again!
Tom Beauford P.S.M.
MrSmith
« Reply #14 on: March 19, 2021, 06:47:21 PM »
I use this for getting the name of blocks.
  1. (defun blkName (vlaBlk)
  2.         (if (vlax-property-available-p vlaBlk 'effectivename)
  3.                 (vla-get-effectivename vlaBlk)
  4.                 (vla-get-name vlaBlk)
  5.         )
  6. )
  7.
