Author Topic: set distance by lisp in a dynamic block  (Read 4441 times)
Romero
« on: August 16, 2018, 12:08:46 AM »
Hi.
Maybe someone here in this forum can help me.
I'm trying to set the distance for a dynamic block of a single parameter; which is linear and is called Distance1.
I do not know what I'm doing wrong, but I can not do it and change the desired distance.
He helped me with the functions of Lee Mac, but something is wrong. Any help very similar, I will be completely grateful.
  1. (defun c: ddd (/ obj dd)
  2.
  3. (if (y (setq obj (car (entsel "\ ndynamic block:")
  4. (setq dd (getdist "\ Length:"))))
  5. (= "AcDbBlockReference" (vla- get-objectname (setq obj (vlax-esame-> vla-object obj))))
  6. (=: vlax-true (vla-get-isdynamicblock obj))
  7. )
  8.
  9. (LM: setdynpropvalue obj "Distance1" dd)
  10. )
  11.
  12.
  13. )
  14.
  15.
  16. (defun LM: setdynpropvalue (blk prp val)
  17. (setq prp (strcase prp))
  18.
  19. (vl-some        '(lambda (x)
  20. (if (= prp (strcase (vla-get-propertyname x)))
  21. (progn
  22. (vla- put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
  23. (cond (val) (t))
  24. )
  25. )
  26. )
  27. (vlax-invoke blk 'getdynamicblockproperties)     ) )
Dlanor
Re: set distance by lisp in a dynamic block
« Reply #1 on: August 16, 2018, 02:42:01 AM »
Your parentheses were a bit out, and there were spurious spaces and spelling mistakes in some activeX function names. Try this:
  1. (defun c: ddd (/ ent obj dd)
  2.
  3. (if (setq ent (car (entsel "\ndynamic block:"))); You are getting an entity here
  4.   (setq dd (getdist "\nLength:"))
  5.   (if (and  (= "AcDbBlockReference" (vla-get-objectname (setq obj (vlax-ename->vla-object ent)))); You're converting to an object here. No spaces in function names
  6.             (= :vlax-true (vla-get-isdynamicblock obj))
  7.       );end_and
  8.     (LM: setdynpropvalue obj "Distance1" dd)
  9.   );end_if
  10. );end_if
  11. (princ)
  12. );end_defun
  13.
And compare it with your code.
steve.carson
« Reply #2 on: August 16, 2018, 12:12:50 PM »
There is also an extra space in the LM:setdynpropvalue function.
Dlanor
« Reply #3 on: August 16, 2018, 12:29:09 PM »
  :wideeyed: :nerdyembarassed:
steve.carson
« Reply #4 on: August 16, 2018, 12:35:18 PM »
I meant function name. The code shows "LM: setdynpropvalue" when it should be "LM:setdynpropvalue".
Dlanor
« Reply #5 on: August 17, 2018, 07:07:57 AM »
I know, I didn't see it hence the emoticons.
gile
  • Marseille, France
« Reply #6 on: August 17, 2018, 02:47:59 PM »
Looks like a double post...
« Reply #7 on: August 17, 2018, 03:16:15 PM »
Triple post .. on cadtutor too... ::)
