Author Topic: Zoom extent on a close document  (Read 1701 times)
latour_g
« on: August 07, 2018, 04:08:10 PM »
I would like to know if it's possible to make a zoom extent on all layout of a close document ?
Or it's only possible if the drawing is open ?
Thank you
BIGAL
  • 40 + years of using Autocad
Re: Zoom extent on a close document
« Reply #1 on: August 09, 2018, 11:23:08 PM »
You can redefine "CLOSE" so it runs a lisp as part of the close say zoom all layouts then close. Search redefine.
Simplest way is to write your own lisp and use it instead of close, last line in lisp executes Close.
latour_g
« Reply #2 on: August 16, 2018, 03:21:39 PM »
ok thanks I will check that !
BIGAL
« Reply #3 on: August 17, 2018, 04:31:58 AM »
This is one example
; goes trhough all layout tabs and zooms all
; By Alan H june 2011
(command "_.pspace")
(setq curtab (getvar "Ctab"))
(setq this_dwg (vlax-get-acad-object))
(foreach d (layoutlist)
  (setvar "CTAB" d)
  (COMMAND "pSPACE")
  (command "zoom" "C" "400,277" 750) ; in case junk around title block
(setvar "ctab" curtab)
