Author Topic: Navigate dialog box during lisp routine?  (Read 1073 times)
micromachines
« on: August 04, 2018, 01:54:24 PM »
When a dialog box pops up with options (ie, checkboxes, dropdown menus, buttons), is it possible to navigate the dialog box using a lisp routine without user input? This is not a standard autocad dialog box so it cannot be suppressed to the command line.
If the dialog box were written in DCL, would it be possible to look at the code there and possibly translate the functions to something that can be controlled via the command line?
Thanks.
tombu
  • ByLayer=>Not0
Re: Navigate dialog box during lisp routine?
« Reply #1 on: August 04, 2018, 04:08:30 PM »
If you have the lisp it could be modified to operate without the dcl file.
Tom Beauford P.S.M.
