(command "-layer" "set" "0" "")(command ".zoom" "E")(command "_.close" "");;Closes Drawing with Saving
I am using the acaddoc.lsp to do some simple routine to batch some files. However on some of the dwgs when it saves (not all), it saves it as save4112.tmp file. Then the original dwg file is gone. Any idea?Code: [Select](command "-layer" "set" "0" "")(command ".zoom" "E")(command "_.close" "");;Closes Drawing with SavingSo if I have a Plan Sheet1.dwg. it would save it as a save4112.tmp. Then the Plan Sheet1.dwg seice to exisit...
