Author Topic: Layer Create with IF and Progn  (Read 1615 times)
Sam
« on: July 31, 2018, 11:49:16 AM »
Dear sir,
i am looking create a layer if not found in drawing and its already in drawing the continue the program
confusion in this code its required progn or not
;----------------- Create layer if not found layer in drawing or its found the layer continue the program (opt-1)
(If (Null Mytextlayer)                                                          ;If Start
 (Progn (Setq (Mytextlayer "MYTEXT")                                            ;Layer is MYTEXT
              (Setq txlayer (Tblsearch "layer" Mytextlayer))                    ;Search in layer table
              (If (Null txlayer)                                                ;If not found MYTEXT Layer
               (Progn (Setq Mytextlayer ()                                      ;confusion this line is required or not
                            (Command "layer" "m" mytextlayer ""))               ;create layer MYTEXT
                ;If already layer its exist, then continue the program
« Last Edit: July 31, 2018, 11:56:36 AM by Sam »
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
Re: Layer Create with IF and Progn
« Reply #1 on: July 31, 2018, 12:07:25 PM »
Maybe:
(defun _makelayer (Mytextlayer)
  (or (Tblsearch "layer" Mytextlayer)
There is also THIS from many moons ago.
« Reply #2 on: July 31, 2018, 04:40:26 PM »
Coincidence: I just posted a routine to something like this.
http://www.theswamp.org/index.php?topic=54354.msg589227#msg589227
Sam
« Reply #3 on: August 01, 2018, 02:06:05 AM »
dear sir jhon
i look at same code thanks
and ron sir,
