Author Topic: findfile without dialogbox  (Read 3711 times)
Amsterdammed
« on: June 03, 2005, 12:56:55 PM »
Does in VBA something like findfile in Lisp exist or does it always open the dialog? :?:
« Reply #1 on: June 03, 2005, 01:26:31 PM »
You can use something like this:
Dim filenamewithpath As String
Dim filename As String
filenamewithpath = "C:\Program Files\ACAD2006\SomelispFile.lsp"
filename = Dir(filenamewithpath)
If filename = "" Then
 MsgBox "File does not exist"
End If
Amsterdammed
« Reply #2 on: June 03, 2005, 02:06:33 PM »
I understand this.
My Problem is that I work for company with offices in different towns, every office is run by different IT clowns with different working methodes. So I don't know the locations where my code must find a certain file. In lisp i would let it search with findfile  for my mnl file and than I know the location where my stuff is parked.
« Reply #3 on: June 03, 2005, 04:06:25 PM »
I think what you are looking for is an implementation of FindFirstFile and FindNextFile API calls that will work in VBA. Go to this page, type findfirst into the Search for box and then press [Search VBNet].
Example1; example2.
/perhaps
Amsterdammed
« Reply #4 on: June 18, 2005, 09:54:11 AM »
I found this on the web, posted by Bob Wahr in 2003
Private Function FindFile(strFile As String)
Dim strSupPth As String
Dim varPaths As Variant
Dim intCnt As Integer
Dim strFnd As String
Dim strTest As String
Dim strDwgDir As String
strSupPth = ThisDrawing.GetVariable("acadprefix")
strDwgDir = ThisDrawing.GetVariable("dwgprefix")
strTest = Dir(CurDir & "\" & strFile, 31)
If strTest <> "" Then
strFnd = CurDir & "\" & strTest
Else
strTest = Dir(strDwgDir & "\" & strFile, 31)
strFnd = strDwgDir & "\" & strFile
Else
If strSupPth <> "" Then
varPaths = Split(strSupPth, ";", -1, vbTextCompare)
For intCnt = 0 To UBound(varPaths)
strTest = Dir(varPaths(intCnt) & "\" & strFile, 31)
strFnd = varPaths(intCnt) & "\" & strFile
Exit For
End If
Next intCnt
End If
End If
End If
FindFile = strFnd
End Function
