Author Topic: Any way to suppress dynamic block message. Like a no for all opened files?  (Read 7874 times)
3dwannab
See:
I want to batch my block library files with lisps and scripts but this message it a pain in my derriere.
cadtag
maybe try running thru accoreconsole.exe instead of the gui?
3dwannab
Thanks, I may try that this evening when I have time and come back with my result.
3dwannab
Yes, I've done that accoreconsole.exe method using ScriptPro but it'll only run the scr.
Not sure how to run my autorun lisp files on them when a drawing opens from my block library.
SP fails when running in ACAD.exe mode.
Maybe there's a regedit item that could be modified!!  :knuppel2:
Does the EXPERT variable suppress that dialog?
3dwannab
Nope, already tried that.
Pretty sure there'll never be a no for all when opening multiple drawings containing parameters!
Still searching regedit for it.
ribarm
  • Marko Ribar, architect
Why don't you hit No and then exit BEDITOR and QSAVE DWG... I think the pop up sould dissappear then...
M.R. on Youtube
3dwannab
I want to open every block file in my block library so doing that for the amount of DYN drawings (300+) I have would be just  :idiot2:
ribarm
This only tells us that you acquired dynamic blocks from other source... You haven't created them... If you want you could zip them and share link over dropbox or cloud and with help of others they could be resaved in format you desire... But I suppose you refuse to share them despite they are not your courtesy???
M.R. on Youtube
3dwannab
You assume wrong. I've been making DBs from they were first added to ACAD.
My courtesy. Really?
I don't want them resaved in any format. I can use a plugin on the app store for that. Maybe re-read what I've said instead of slandering me that might set you straight. And no, you can't have my 300+ DB block dwgs that I've spent the last 12 years working on.
Here you can have one as a good will gesture.
I really hope this isin't as unwelcoming as the foobar2000 forum.
Master_Shake
I'm confused as to what you are asking in general, not specifically. What are you attempting to do with block.dwg file in your processes?
Importing the block.dwg file into an existing drawing should not cause that dialog to display and allow full function of the block. You can then export the block out into a block.dwg file. However, opening the block.dwg file should cause that dialog to appear as AutoCAD is alerting you to the fact it isn't really a drawing file.
To answer your specific question, there are 3rd party applications which can automatically select an option for a dialog prompt. Something similar to ClickYes.
« Last Edit: July 23, 2018, 08:43:13 AM by Master_Shake »
huiz
  • Certified Prof C3D
In the OP he clearly explains that he want to batch process his blocks. Probably in this batch process the blocks need to be opened (as single drawings), do something and then save. So it is not about inserting the blocks in a current drawing and save that.
The messagebox can't be suppressed unfortunately, at least I've not found a solution for Lisp nor Script. I assume you can write a .NET plugin that opens each drawing and process it as a side database. But then you must be capable of writing plugins.
Normally The Swamp is very welcoming to new members but I think not everybody did understand the question completely :-)
3dwannab
Exactly, what my next thing was to do. I opened up spy++ to check that dialog and look for it in the registry but there was nothing. I'll look into that app. Thank you.
Precisely what I intend to do. My habit of blocks management is to have them as separate dwgs.
This dialog doesn't appear when you BEDIT them in a drawing. But this doesn't help me here.
3dwannab
Found DialogDevil which is the ticket.
Simply, drag the icon to the No button and it'll close it automatically thereafter.
Case closed. Thanks guys for your help.
ED.
Spoke to soon. It appears that pesky dialog has a different handle every time.
3dwannab
This is two different dwg files with authoring elements. 2 handles / 1 dialog.
As two cancels on the keyboard can get rid of that dialog, I also tried to put
(command ^C^C) in my accaddoc lsp but it doesn't work. That dialog prevents that from happening or it just doesn't work.
« Last Edit: July 23, 2018, 11:38:30 AM by 3dwannab »
