Author Topic: True Color  (Read 1410 times)
GDF
True Color
« on: July 04, 2018, 03:31:25 PM »
Need some help making this routine work for creating a layer with true color.
(ARCH:MLYR "NEW-MFC" 247,28,8 "Continuous" "0.01")
(defun ARCH:MLYR  (LA LC LT LW)
  (ARCH:LINETYPE)
  (command "cecolor" "bylayer")
  (setvar "cmdecho" 0)
  (if (tblsearch "layer" LA)
    (progn (command "layer" "Thaw" LA "") (command "layer" "Set" LA ""))
    (progn (command "layer" "Make" LA)
           (command "Color")
           (command "Truecolor" LC "")
           (command "Ltype" LT "" "LWeight" LW "" "")))
  (setvar "cmdecho" 1)
  (princ))
GDF
Re: True Color
« Reply #1 on: July 04, 2018, 03:34:18 PM »
oops
(ARCH:MLYR "NEW-MFC" "247,28,8" "Continuous" "0.01")
GDF
Re: True Color
« Reply #2 on: July 04, 2018, 03:55:54 PM »
(defun ARCH:LYR-RGB  (LA LC LT LW LD)
  (ARCH:LINETYPE)
           (command "Color")
  (setq newLayer
         (vla-Add
           (vla-Get-Layers (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
           LA))
  (vla-Put-Description newLayer LD)
  (princ))
;;;(ARCH:LYR-RGB "NEW-MFC" "247,28,8" "Continuous" "0.01" "New MFC")
Re: True Color
« Reply #3 on: July 06, 2018, 07:51:24 PM »
GDF
Re: True Color
« Reply #4 on: July 07, 2018, 01:38:14 PM »
Thanks Alan and Lee
