Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Select ONLY Layout's Page Sets
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Select ONLY Layout's Page Sets (Read 1882 times)
Clujna
Mosquito
Juanjo, draftsman
on:
July 02, 2018, 07:06:30 AM »
Hi all,
I'm trying to convert this function:
(defun AllPS (/)
(vla-get-plotconfigurations
...to one that returns only the layouts page sets.
I summarize my (fruitless) attempts, based in variations of jtbworld's Pagesetup tools:
(defun AllPS (/ aps)
(setq aps (ssadd))
(vlax-for pc (vla-get-plotconfigurations
(vla-get-activedocument (vlax-get-acad-object)))
(if (= (vla-get-modeltype pc) :vlax-false)
(ssadd (vlax-vla-object->ename pc) aps)
(setq aps (ssadd))
(ssadd pc aps)
I will appreciate any help.
Logged
Juan José Bernal, civil works draftsman
Needs a day job
Re: Select ONLY Layout's Page Sets
Reply #1 on:
July 02, 2018, 09:15:30 AM »
Give this a try:
Code - Auto/Visual Lisp:
[Select]
defun
allps
aps
;; You need to create a list of plotconfigurations not a selection set
;;(setq aps (ssadd))
vlax-for
pc
if
vla-get-modeltype
pc
:vlax-false
setq
aps
cons
pc aps
;; Return the value
aps
if
allps
mapcar
vla-get-name
allps
Logged
Clujna
Mosquito
Juanjo, draftsman
Reply #2 on:
July 03, 2018, 04:42:25 AM »
Thank you Mr. Ronjonp, forgive the delay in responding, a lot of work here, besides the hourly difference.
Unfortunately, it does not work. I think it's because of the way he returns the list.
Original function:
Command: (allps)
# <VLA-OBJECT IAcadPlotConfigurations 00000000565eebe8>
Modified function:
Command: (allps)
(# <VLA-OBJECT IAcadPlotConfiguration 000000005e898248>)
The function is within a command published here by Mr. Irné Barnard, whom I have tried to request permission to modify without success. I expect not to be breaking any norm of this forum
http://forums.augi.com/showthread.php?117284-LayoutTools-Explained&highlight=layouttools
In the original command the function is called "Get-Tab-Col".
Logged
Needs a day job
Reply #3 on:
July 03, 2018, 09:20:39 AM »
What are you trying to do with this?
Logged
tombu
Bull Frog
ByLayer=>Not0
Reply #4 on:
July 03, 2018, 03:04:42 PM »
See also:
http://forums.augi.com/showthread.php?172048-Select-ONLY-Layout-s-Page-Sets&p=1336601#post1336601
Logged
Tom Beauford P.S.M.
Clujna
Mosquito
Juanjo, draftsman
Reply #5 on:
July 04, 2018, 08:55:36 AM »
I want only the paper space page settings to appear in the dialog box, if it's possible. Believe me, I've tried it on my own.
Universal excuses if I am not using absolutely correct the forum.
PD: ...and for my English
Logged
Needs a day job
Reply #6 on:
July 05, 2018, 10:33:18 AM »
Maybe
THIS
is what you need.
Logged
Clujna
Mosquito
Juanjo, draftsman
Reply #7 on:
July 06, 2018, 05:27:16 AM »
Yes Ron, that's exactly it. Many thanks.
I hope to understand someday how it does, apart from using it.
I leave you a written function in my Paleozoic AutoLISP, a clear demonstration that I must continue to improve.
Greetings.
Logged
Needs a day job
Reply #8 on:
July 06, 2018, 10:08:25 AM »
That's pretty slick .. thanks for sharing
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
