Author Topic: Draw Sun Angle in Plan  (Read 2145 times)
GDF
« on: June 22, 2018, 08:15:43 AM »
I'm fishing for a lisp routine that will draw in plan the sun angle based upon AutoCAD's Geographic Location palette settings.
GDF
Re: Draw Sun Angle in Plan
« Reply #1 on: June 22, 2018, 08:34:30 AM »
huiz
  • Certified Prof C3D
« Reply #2 on: June 22, 2018, 10:01:39 AM »
GDF
« Reply #3 on: June 22, 2018, 01:36:14 PM »
(defun C:SUN1 ()(command "start" "http://andrewmarsh.com/apps/releases/sunpath2d.html")(princ))
(defun C:SUN2 ()(command "start" "http://www.sunpath.in/#/29.1617,-82.1779,12/2018.06.22/13:51")(princ))
GDF
« Reply #4 on: June 24, 2018, 12:27:26 PM »
Ok, you math-trig masters:
What I am trying to achieve is the approximate shadow angle calculator for a vertical wall... solar zenith angle. by plugging in the necessary variables.
(hopefully I'm expressing this correctly)
Lattitude =
Time of day =
Month =
To get the solar zenith angle
Can anyone help me with a calculator formula example?
;;;https://en.wikipedia.org/wiki/Solar_azimuth_angle#Formulas
huiz
« Reply #5 on: June 24, 2018, 02:47:30 PM »
You can download an Excel file here:
https://www.esrl.noaa.gov/gmd/grad/solcalc/NOAA_Solar_Calculations_day.xls
Fill in the location and date and it will fill everything you need. Formulas are in the cells.
Be aware of the theoretical results, For really accurate calculations you need to respect the influence of the atmosphere, true north and the elevation of EG (or bumpy terrains). I think a few degrees are acceptable for theoretical calculations.
GDF
« Reply #6 on: June 24, 2018, 03:04:30 PM »
I'm also looking for additional drawing files from different latitudes like the one enclosed for London:
