Author Topic: Problem publishing to PDF (assume its a setting)  (Read 3188 times)
CottageCGirl
« on: June 21, 2018, 10:52:20 AM »
good morning..
banging my head against the desk.. cant seem to figure out the issue.. ACAD looks totally normal but when it goes to pdf publish, it does this.. HALP.... please   :thinking:
Re: Problem publishing to PDF (assume its a setting)
« Reply #1 on: June 21, 2018, 10:56:13 AM »
maybe ............
rw2691
« Reply #2 on: June 21, 2018, 11:14:44 AM »
It may not be related to your issue, but I just went through a PDF problem directly after a recent upgrade to Windows 10. I hope the coincidence was not related. My problem was that the Plot Styles Table was not working with the PDF. I resolved the issue by exposing all the layers in the drawing, then selecting all the objects, and pasting them to a fresh blank drawing. My original drawing file had become corrupted.
Rick
alterego
« Reply #3 on: June 21, 2018, 11:20:24 AM »
That almost looks like annotative text showing there.
« Reply #4 on: June 21, 2018, 12:20:07 PM »
annotative text
psltscale?
a copy of the file or a portion thereof would sure help
pendean
  • Mosquito
  • "I am not a number, I am a free man"
« Reply #5 on: June 21, 2018, 01:50:15 PM »
See your other duplicate post for additional responses.
CottageCGirl
« Reply #6 on: June 26, 2018, 10:39:49 AM »
Sorry about that, my new work network seems to lag it so I need to hit "post" and when it says it didnt post, check first before I try again.
CottageCGirl
« Reply #7 on: June 26, 2018, 10:52:03 AM »
so I cant seem to find a duplicate post.... so I will just shout out here
the PDFSHX set to 0 worked like a charm so thank you whomever suggested that one  :oops:
ChrisCarlson
« Reply #8 on: July 03, 2018, 04:02:47 PM »
The PDFSHX was such a crummy workaround on AutoDesk's part. I forget which version but AutoDesk THEN changed the variable to EPDFSHX and I think it's now back to PDFSHX.
