Author Topic: Dynamic Block Visibility State Options to ComboBox  (Read 3672 times)
Conveyor1
« on: June 18, 2018, 06:57:30 PM »
Afternoon,
I have created an Autocad template and inside this template I have some dynamic blocks with visibility properties.  When required, I would update the block with new visibility options, delete the visible block in the drawing, then save it as the new template for everyone to use.  I have some VB.net code to see if the block exists in the drawing after the program is loaded, but I am looking for a way to populate into a ComboBox the available options from this blocks visibility states.
Does anyone know what field I would need to look at to get this information or the best way to get this information?
I would know the name of the uninserted block and the name of the dynamic property.
Please let me know your thoughts.
WILL HATCH
Re: Dynamic Block Visibility State Options to ComboBox
« Reply #1 on: June 18, 2018, 07:15:51 PM »
Think this is essentially what you're looking for, dumps out all the properties by their name:
Code - C#: [Select]
  1.         public static Dictionary<string, DynamicBlockReferenceProperty> getProperties(this BlockReference br, bool IncludeReadOnly)
  2.         {
  3.             if (!br.IsDynamicBlock) return null;
  4.             DynamicBlockReferencePropertyCollection coll = br.DynamicBlockReferencePropertyCollection;
  5.             if (coll.Count == 0) return null;
  6.             Dictionary<string, DynamicBlockReferenceProperty> props = new Dictionary<string,DynamicBlockReferenceProperty>();
  7.             foreach (DynamicBlockReferenceProperty prop in coll)
  8.             {
  9.                 if (IncludeReadOnly | !prop.ReadOnly)
  10.                     props.Add(prop.PropertyName, prop);
  11.             }
  12.             return props;
  13.         }
Conveyor1
« Reply #2 on: June 18, 2018, 07:23:58 PM »
Afternoon,
Thank you for the quick reply.  Let me see if I can reprogram the structure to VB.net and see how it goes.
Conveyor1
« Reply #3 on: June 18, 2018, 10:04:34 PM »
Evening, I tried to keep the same idea of you code and do it a VB.net format.
However, I am not getting the result i was looking for.
For example, I want to find the dynamic block property named Visibility1, then find what options are available Visibility1.  So under Visiblity1, i could have state1, state2, state3, etc.
The code provided gives me the names of the available dynamic block properties and or what their currect setting is.
                ' Dynamic Block Type Check for Testing
                Dim myDBRPC As DynamicBlockReferencePropertyCollection = myBlkRef.DynamicBlockReferencePropertyCollection
                Dim myDBRP As DynamicBlockReferenceProperty
                Dim list1 As String = ""
                Dim list2 As String = ""
                For Each myDBRP In myDBRPC
                    list1 = list1 + myDBRP.Value.ToString
                    list2 = list2 + myDBRP.PropertyName.ToString
                Next
But I could have done something wrong.
Please let me know when you can.
WILL HATCH
« Reply #4 on: June 19, 2018, 04:10:52 PM »
I've never had any compelling reason to go down this path, but I did manage to find a page that helped me turn back all those years ago... http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod06e.htm
Conveyor1
« Reply #5 on: June 19, 2018, 04:41:33 PM »
That is about 7 levels above my knowledge.  I did find this.
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html
Only issue I have is I have an understanding of VB.net and not so much the C# side.  Anyone have a Rosetta Stone?
WILL HATCH
« Reply #6 on: June 19, 2018, 06:07:06 PM »
Haha, nope. I surveyed the community before choosing language originally to avoid this sort of thing. Good luck
Conveyor1
« Reply #7 on: June 25, 2018, 09:10:39 AM »
Morning,
We were close.
Turns out myDBRP..GetAllowedValues has the information I am looking for.
WILL HATCH
« Reply #8 on: June 26, 2018, 04:11:29 PM »
Oh geeze... there it is staring at me from the documentation...  :idiot2: :whistling:
