Author Topic: Exploding AEC Objects  (Read 12028 times)
Re: Exploding AEC Objects
« Reply #15 on: June 14, 2018, 12:35:24 PM »
From the little bit I've gleaned from this thread it appears all you need do is write a wrapper for -exporttoautocad and (perhaps the) ability to batch same.
cmwade77
« Reply #16 on: June 14, 2018, 12:36:58 PM »
Not really, as that creates a new drawing and often crashes in the process.
huiz
  • Certified Prof C3D
« Reply #17 on: June 14, 2018, 01:28:48 PM »
Exactly, we don't get that level of control, many of our clients either refuse or don't know how to do so. We also have so many infected drawings on our system that our files get infected quickly. Honestly, these are harder to eliminate than the Education Stamp was when that was an issue.
You can use the object enablers so there is no need to explode the objects. Sometimes it gives unpredictable results because of their design.
BTW, in AutoCAD 2019 the Educatational Plot Stamp is back. That might be worse news.
Coder
« Reply #18 on: June 14, 2018, 01:33:23 PM »
Quote from: Coder
I am using Autocad 2017
You'll have to use Civil 3D (or perhaps AutoCAD Arch?) to run this command.
It is AutoCAD Architectural.
cmwade77
« Reply #19 on: June 14, 2018, 01:43:12 PM »
No, I can't, object enablers cause AutoCAD to run very, very poorly and crash A LOT more often. No, it is far better to eliminate these viruses.
Jeff H
« Reply #20 on: June 14, 2018, 01:46:36 PM »
Even if you figure out how to expolde the aec objects your drawing will still be "infected" and that's why the exporttoautocad command creates a new drawing. There are drawing variables, dictionaries, etc... that will still be drawing, cause object enablers to load, infect other drawings.
If your end goal is to get rid of all the AEC stuff, and not have it affect other drawings, I dont think you have another option than creating a new drawing.
I did what MP already mention, I coded up a routine that takes all .dwg files in folder and batches the exporttoacad command placing them into a folder called "exported".
dgorsman
« Reply #21 on: June 14, 2018, 02:02:49 PM »
All entities are objects, but not all objects are entities, so not everything can be literally "exploded".  Non-entity objects must be deleted.
Not everything needs to come from verticals either.  The "-dwgunits" command will load the base AEC enablers included with vanilla AutoCAD and add AEC objects to the file (and possibly other files already open in the same session, although I haven't deliberately tested that particular sequence).
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
VovKa
  • Ukraine
« Reply #22 on: June 14, 2018, 03:24:37 PM »
Dave M
« Reply #23 on: June 15, 2018, 01:01:37 PM »
have you tried http://www.maestrogroup.com.ua/support/ExplodeProxy.zip ?
That works great! Do you know if there is an English language version?
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
VovKa
  • Ukraine
« Reply #24 on: June 15, 2018, 03:01:30 PM »
the author of this program is our fellow swamper Alexander Rivilis, so you can ask him directly :)
if you want Readme.txt translated just use google's translate
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #25 on: June 15, 2018, 03:29:56 PM »
There is no English version, but it is easy to translate messages with help of Google translate.
For example:
Удалено Proxy: Новых объектов:
Removed Proxy: New objects:
Dave M
« Reply #26 on: June 15, 2018, 03:51:51 PM »
For example:
When I paste the Readme file into Google Translate, it can't recognize the text.  I think it's because of the font?
Alexander Rivilis
« Reply #27 on: June 15, 2018, 04:30:09 PM »
Google translate without problem:
cmwade77
« Reply #28 on: June 15, 2018, 04:37:50 PM »
Yeah, definitely a font issue, instead of what you see, we get characters like:
Copyright (c) 1998-2011 Александр Ривилис
Данная лицензия разрешает, безвозмездно, лицам, получившим копию данного
программного обеспечения и сопутствующей документации (в дальнейшем
именуемыми "Программное Обеспечение"), использовать Программное
Обеспечение без ограничений, включая неограниченное право
на использование, копирование, изменение, добавление, публикацию,
распространение, сублицензирование и/или продажу копий Программного
Обеспечения, также как и лицам, которым предоставляется данное
Программное Обеспечение, при соблюдении следующих условий:
Вышеупомянутый копирайт и данные условия должны быть включены во все
копии или значимые части данного Программного Обеспечения.
ДАННОЕ ПРОГРАММНОЕ ОБЕСПЕЧЕНИЕ ПРЕДОСТАВЛЯЕТСЯ <КАК ЕСТЬ>, БЕЗ ЛЮБОГО ВИДА
ГАРАНТИЙ, ЯВНО ВЫРАЖЕННЫХ ИЛИ ПОДРАЗУМЕВАЕМЫХ, ВКЛЮЧАЯ, НО НЕ
ОГРАНИЧИВАЯСЬ ГАРАНТИЯМИ ТОВАРНОЙ ПРИГОДНОСТИ, СООТВЕТСТВИЯ ПО ЕГО
КОНКРЕТНОМУ НАЗНАЧЕНИЮ И НЕНАРУШЕНИЯ ПРАВ. НИ В КАКОМ СЛУЧАЕ АВТОРЫ ИЛИ
ПРАВООБЛАДАТЕЛИ НЕ НЕСУТ ОТВЕТСТВЕННОСТИ ПО ИСКАМ О ВОЗМЕЩЕНИИ УЩЕРБА,
УБЫТКОВ ИЛИ ДРУГИХ ТРЕБОВАНИЙ ПО ДЕЙСТВУЮЩИМ КОНТРАКТАМ, ДЕЛИКТАМ ИЛИ
ИНОМУ, ВОЗНИКШИМ ИЗ, ИМЕЮЩИМ ПРИЧИНОЙ ИЛИ СВЯЗАННЫМ С ПРОГРАММНЫМ
ОБЕСПЕЧЕНИЕМ ИЛИ ИСПОЛЬЗОВАНИЕМ ПРОГРАММНОГО ОБЕСПЕЧЕНИЯ ИЛИ ИНЫМИ
ДЕЙСТВИЯМИ С ПРОГРАММНЫМ ОБЕСПЕЧЕНИЕМ.
« Reply #29 on: June 15, 2018, 04:59:34 PM »
Yeah, definitely a font issue, instead of what you see, we get characters like...
Try opening the text file in Notepad++  :wink:
