Hi.
The way I work with dwg files is I always have a frame block in the model space that is of size of the paper and has appropriate annotative scale.
Then I go to paper space, and through the viewport I am navigating to this block and setting the scale accordingly. See attached file for reference.
I am willing to write a code that would allow me:
- While being on the paper space go inside the viewport, select the frame block in modelspace - after this annotative scale of the viewport and it's coordinates should be adjusted based on scale and location of the frame block in model space.
This would be useful every time I would create a new page.
Are there some functions that would allow to set coordinates and annotative scale of the viewport?
Express tools has a similar command but it's not exactly the same....
Thank you
