I modified BlockInfo.Lsp by Alan (CAB) to find insertion points of nested blocks, but the results I got are definition of insertion blocks.
My question is how can I get the real world coordinates of insertion points of this nested blocks?
I know I have to utilize some kind coordinates transformation, can you give me a pointer for coordinates transformation especially for rotated blocks?
Any help is greatly appreciated. Thanks.
EDIT I: I used Refgeom (Gile) function as advised by Lee Mac, but I don't know how to apply the Transformation matrix.
EDIT II: PROBLEM SOLVED
;;; FUNCTION BlockInfo.lsp
;;; Send a block definition to text file "Block Data-[block name].txt"
;;; You should view text file with word wrap off because
;;; some of the lined are very long
;;; ARGUMENTS
;;; none
;;; USAGE
;;; BlockInfo
;;; PLATFORMS
;;; 2000+
;;; AUTHOR
;;; Copyright© 2004 Charles Alan Butler
;;; ab2draft@TampaBay.rr.com
;;; VERSION
;;; 1.1 Sep. 23, 2004
;;; This routine may be used and copied for non-profit
;;; purposes only. If you wish to include any of the file in a
;;; commercial program, contact the author.
(defun c:BlockInfo (/
bname dxf data indent fname fn blkcnt indent
;; extract the data from dotted pair
(defun dxf (x) (cdr (assoc x data)))
(if (setq bname (entsel "Pick a block: "))
(if (and (setq data (entget (car bname)))
(or (= "INSERT" (dxf 0))
(= "DIMENSION" (dxf 0))
) ;and
(setq parent_enm (car bname))
(setq bname (dxf 2))
);end progn
(setq bname nil)
) ;if
(if (and
(setq bname (getstring t "\nEnter the block name: "))
(setq ss (ssget "_X" (list '(0 . "INSERT")(cons 2 bname))))
(setq ename (ssname ss 0)))
(princ); got a block
(setq bname nil); GETNAME FAILED
); if
) ;if
(bname
(setq Fname (Strcat "Block Data-" bname ".txt"))
(setq fn (open fname "w"))
(prt "===============================================")
(prt " BlockInfo.lsp")
(prt " Charles Alan Butler")
(prt " ab2draft@TampaBay.rr.com")
(prt " 09/23/2004 Ver 1.1")
;; Create current Date & Time
(setq tmp (rtos (getvar 'cdate) 2 4))
(setq tmp (strcat " << File Date "
(substr tmp 5 2) "/" (substr tmp 7 2) "/"
(substr tmp 1 4) "@" (substr tmp 10 2) ":"
(substr tmp 12 2) " >>"
(prt tmp)
(setq blkcnt 0
indent "| "
(listb bname)
(prt "*********** END OF PARENT BLOCK *************")
(setq indent nil)
(prt "= End of Routine =")
(close fn)
(prompt (strcat "\nBlock data written to file: " fname))
(t (print " no block found."))
) ;cond
;; do the actual line print to file
(defun prt (txt)
(if indent
(princ indent fn)
(princ txt fn)
(write-line "" fn)
;; This sub routine does all the work
(defun listb (bname / dxf data wait)
;; return value from a dotted pair
;; begin the main program
(if (= blkcnt 0)
(setq header (strcat " Parent Block : " bname))
(setq header (strcat " Sub Block "
(itoa blkcnt); number of nested levels
bname
(prt "***********************************************")
(prt header)
(prt (setq data (entget(tblobjname "block" bname))))
(prt "--------- Objects In Block ----------------")
(setq data (dxf -2)) ; get first entity
(prt (setq data (entget data '("*")))) ; get assoc list
(while data
(if (= (dxf 0) "INSERT")
(setq blkcnt (1+ blkcnt)
indent (strcat indent "| ")
(if (= (cdr (assoc 2 data)) "DRIVINGPILE")
(princ "\n. DXF-CODE 10 = ")
(princ (cdr (assoc 10 data)))
(princ "\t is not an insertion point of nested block")
;; Lee Mac said, I need to use RefGeom (gile), but how?
(setq Transmatrix_point (refgeom (cdr (assoc -1 data))))
(princ "\n. Transformation data: ")
(princ Transmatrix_point)
(setq ipt (trans (cdr (assoc 10 data)) (cdr (assoc 210 data)) 0))
(entmake
(list
'(0 . "POINT")
(cons 10 (apply '(lambda ( m v ) (mapcar '+ (mxv m ipt) v)) (refgeom (cdr (assoc -1 (entget parent_enm))))))
);end progn
);end if
(listb (dxf 2))
(setq indent (substr indent 3))
(prt "************ END OF SUB BLOCK **************")
(if (setq data (entnext (dxf -1)))
);end progn
);end if
) ;while
(prompt "\nBlock Info Loaded, Enter BlockInfo to run.")
;;;--- end of file -----------------------------------------
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
(defun refgeom ( ent / ang enx mat ocs )
(setq enx (entget ent)
ang (cdr (assoc 050 enx))
ocs (cdr (assoc 210 enx))
(list
(setq mat
(mxm
(mapcar '(lambda ( v ) (trans v 0 ocs t))
(1.0 0.0 0.0)
(0.0 1.0 0.0)
(0.0 0.0 1.0)
(mxm
(list
(list (cos ang) (- (sin ang)) 0.0)
(list (sin ang) (cos ang) 0.0)
'(0.0 0.0 1.0)
(list
(list (cdr (assoc 41 enx)) 0.0 0.0)
(list 0.0 (cdr (assoc 42 enx)) 0.0)
(list 0.0 0.0 (cdr (assoc 43 enx)))
(mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
(mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix Transpose - Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
(apply 'mapcar (cons 'list m))
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
