// Open the Block table for read
BlockTable acBlkTbl;
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
ObjectId blkRecId = ObjectId.Null;
if (!acBlkTbl.Has("ISITMA BORU ÇAPI "))
using (BlockTableRecord acBlkTblRec = new BlockTableRecord())
acBlkTblRec.Name = "ISITMA ÇAP";
// Set the insertion point for the block
acBlkTblRec.Origin = new Point3d(0, 0, 0);
// Add a circle to the block
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(0, 0, 0);
acCirc.Radius = 10;
acBlkTblRec.AppendEntity(acCirc);
// Add an attribute definition to the block
using (AttributeDefinition acAttDef = new AttributeDefinition())
acAttDef.Position = new Point3d(0, 0, 0);
acAttDef.Prompt = textBox2.Text;
acAttDef.Tag = textBox3.Text;
acAttDef.TextString = comboBox1.Text;
acAttDef.Height = 1;
acAttDef.Justify = AttachmentPoint.MiddleCenter;
acBlkTblRec.AppendEntity(acAttDef);
acBlkTbl.UpgradeOpen();
acBlkTbl.Add(acBlkTblRec);
acTrans.AddNewlyCreatedDBObject(acBlkTblRec, true);
blkRecId = acBlkTblRec.Id;
else
blkRecId = acBlkTbl["CircleBlockWithAttributes"];
// Insert the block into the current space
if (blkRecId != ObjectId.Null)
BlockTableRecord acBlkTblRec;
acBlkTblRec = acTrans.GetObject(blkRecId, OpenMode.ForRead) as BlockTableRecord;
// Create and insert the new block reference
using (BlockReference acBlkRef = new BlockReference(new Point3d(2, 2, 0), blkRecId))
BlockTableRecord acCurSpaceBlkTblRec;
acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
acCurSpaceBlkTblRec.AppendEntity(acBlkRef);
acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
// Verify block table record has attribute definitions associated with it
if (acBlkTblRec.HasAttributeDefinitions)
// Add attributes from the block table record
foreach (ObjectId objID in acBlkTblRec)
DBObject dbObj = acTrans.GetObject(objID, OpenMode.ForRead) as DBObject;
if (dbObj is AttributeDefinition)
AttributeDefinition acAtt = dbObj as AttributeDefinition;
if (!acAtt.Constant)
using (AttributeReference acAttRef = new AttributeReference())
acAttRef.SetAttributeFromBlock(acAtt, acBlkRef.BlockTransform);
acAttRef.Position = acAtt.Position.TransformBy(acBlkRef.BlockTransform);
acAttRef.TextString = acAtt.TextString;
acBlkRef.AttributeCollection.AppendAttribute(acAttRef);
acTrans.AddNewlyCreatedDBObject(acAttRef, true);
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
