Author Topic: Change Multiple dimension values at once  (Read 1435 times)
hudster
« on: May 31, 2018, 09:26:46 AM »
I have a building with multiple long corridors, currently we have lights all along it, spaced at 3000mm intervals, I need to change them to 2400mm intervals.
They all have dimensions, does anyone know of a way I can change the values to 2400 en-masse?
If it wan't for the fact there are multiple fitting types, I'd just array a new set and I'd be done, but having to change them all is a real pain.
MexicanCustard
Re: Change Multiple dimension values at once
« Reply #1 on: June 04, 2018, 01:37:08 PM »
Can you make a project parameter and link all the dimensions to that parameter?
