Author Topic: Civil3D - Qselect Cogo point by Label Style  (Read 4303 times)
MSTG007
« on: May 23, 2018, 12:26:49 PM »
I am having a hard time trying to figure out how to select all cogo points with the same Label Style via the Qselect interface.
I have a blank civil3D drawing. Created some cogo points and used standard on everything. Still the quick select will not select them.
Is there a certain way to do these or do I need another method to get it to select them?
Civil3D 2020
Squirltech
Re: Civil3D - Qselect Cogo point by Label Style
« Reply #1 on: May 23, 2018, 01:34:03 PM »
Select COGO point, Right click, Select similar
"The only thing left to do is everything" - Jesse James
MSTG007
« Reply #2 on: May 23, 2018, 01:39:15 PM »
Interesting... I also was playing around with it more. I can sort all the points by Point Label Style then, Select them. (There is my selection set). I can then take that Selection set and add it to a new point group!
Civil3D 2020
« Reply #3 on: June 14, 2018, 03:22:12 PM »
The prospector tab is your friend!
AND,  as you know by now
Autocad and C3D do NOT play well together
