If I run Example_GetPaperMargins from:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-ActiveX/files/GUID-2CF57709-4DBE-4CBE-A4AF-45D90C8F8B54-htm.htmlin a empty metric DWG > printer = "None" I get:
____________________________________________________________________________
Paper plot information for the current drawing is: Layout1
The paper size for this layout is: 215.9 X 279.4 millimeter(s)
The paper margins are:
Left (6.35) millimeter(s)
Right (6.35) millimeter(s)
Top (6.35) millimeter(s)
Bottom (6.35) millimeter(s)
The paper plot area for this layout is: 215.9 X 279.4 millimeter(s)
Layout2
Is it possible to set PaperMargins to 0?
I need to set Layout to a vla-SetWindowToPlot based un my standard paper (example A3 = 210x297)
and see correct Paper backgroud and printable area without setting a printer.
(vla-SetWindowToPlot LayObj PntT00 PntT02)
(vla-put-PlotType LayObj acWindow)
(vla-Put-CenterPlot LayObj 1)
