I have the program below that opens ODS spreadsheets and I need to have a list of the sheets.
(DEFUN C:TEST ()
(VL-LOAD-COM)
(setq fileName "c:\\test.ODS")
(setq oCalc (ooffice_calc_open filename))
(setq oSheets (vl-catch-all-apply 'vlax-invoke-method (list oCalc 'getSheets)))
;(setq lsheets ...);list of osheets
;(print lsheets)
(vl-catch-all-apply 'vlax-invoke-method (list oCalc 'Dispose))
(defun ooffice_calc_open ( filename / strDocType strVer strNam strFile oDesktop oService oStruct oCalc arrProps)
(if (and ;; check if OOffice is installed
(setq strDocType "StarCalcDocument")
(setq strVer (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\soffice." strDocType "\\CurVer")))
(setq strNam (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\" strVer)))
(setq strFile (vl-registry-read (strcat "HKEY_CLASSES_ROOT\\" strVer "\\protocol\\StdFileEditing\\server")))
(findfile strFile)
(setq oService (vlax-get-or-create-object "com.sun.star.ServiceManager"))
(setq oDesktop (vlax-invoke-method oService "createInstance" "com.sun.star.frame.Desktop"))
(setq oStruct (vlax-invoke-method oService "Bridge_GetStruct" "com.sun.star.beans.PropertyValue"))
(vlax-put-property oStruct "Name" "Show")
(vlax-put-property oStruct "Value" :vlax-true)
(setq arrProps (vlax-make-safearray vlax-vbvariant (cons 0 0)))
(vlax-safearray-put-element arrProps 0 oStruct)
(setq filename (strcat "file:///" (vl-string-translate "\\" "/" FileName)))
(setq oCalc (vlax-invoke-method oDesktop "LoadComponentFromURL" filename "_blank" 0 arrProps))
(vlax-release-object oStruct)
(vlax-release-object oDesktop)
(vlax-release-object oService)
oCalc
