Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Update Code to accept nested Xref
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Update Code to accept nested Xref (Read 1128 times)
HasanCAD
Swamp Rat
on:
May 10, 2018, 06:43:49 AM »
HI all
I want to Change color and LWeight for layers of Xrefs which in Model only. It is working good. but one or more of xrefs has nested Xref.
So, How to do the same for nested Xrefs.
Code - Auto/Visual Lisp:
[Select]
if
Setq
ss
ssget
"_x"
list
cons
0
"INSERT"
cons
410
if
eq
1
getvar
'CVPORT
getvar
'CTAB
"Model"
repeat
setq
i
sslength
ss
setq
s
ssname
ss
setq
i
1-
i
setq
ent
entget
s
setq
xrn
cdr
assoc
2
ent
setq
xrn
strcat
xrn
progn
vlax-for
i
vla-get-Layers
Doc
if
wcmatch
vla-get-Name
i
xrn
progn
vla-put-Color
i Clr
vla-put-lineweight
i acLnWt009
vla-Regen
Doc acActiveViewport
Last Edit: May 13, 2018, 04:31:49 AM by HasanCAD
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
HasanCAD
Swamp Rat
Re: Update Code to accept nested Xref
Reply #1 on:
May 13, 2018, 11:22:39 AM »
This is what I ended to
comments will be valuable
[Select]
defun
c:XrefLayerColor
adoc ACTLAY CLR DOC ENAMES I LAYOUTS PLOT SS XR XREN XRN XRNB XRS XRSS
vl-load-com
defun
*error*
msg
vla-endundomark
doc
if
not
wcmatch
strcase
msg t
"*break,*cancel*,*exit*"
princ
strcat
\n
Error: "
msg
princ
setq
clr
252
setq
doc
vla-get-activedocument
vlax-get-acad-object
vla-startundomark
doc
if
Setq
ss
ssget
"_x"
list
cons
0
"INSERT"
cons
410
if
eq
1
getvar
'CVPORT
getvar
'CTAB
"Model"
repeat
setq
i
sslength
ss
setq
s
ssname
ss
setq
i
1-
i
setq
ent
entget
s
setq
xrnn
cdr
assoc
2
ent
setq
xrn
strcat
xrnn
vlax-for
i
vla-get-Layers
Doc
if
wcmatch
vla-get-Name
i
xrn
progn
vla-put-Color
i Clr
vla-put-lineweight
i acLnWt009
if
setq
ent
tblobjname
"block"
xrnn
while
setq
ent
entnext
ent
if
and
eq
"INSERT"
cdr
assoc
0
entget
ent
setq
entnm
cdr
assoc
2
entget
ent
vla-get-IsXRef
vla-item
vla-get-blocks
doc
entnm
:vlax-true
progn
setq
xrn
strcat
entnm
vlax-for
i
vla-get-Layers
Doc
if
wcmatch
vla-get-Name
i
xrn
progn
vla-put-Color
i Clr
vla-put-lineweight
i acLnWt009
vla-Regen
doc acActiveViewport
vla-endundomark
doc
princ
Logged
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
