Author Topic: Select text with integer string only  (Read 1433 times)
Coder
« on: May 08, 2018, 03:27:39 PM »
Hello guys,
Is it possible to use ssget function with filter to select single text objects with different quantity of integers strings?
Example: 2 45 535 7588 and many more.
Thanks in advance.
ribarm
  • Marko Ribar, architect
Re: Select text with integer string only
« Reply #1 on: May 08, 2018, 05:19:05 PM »
Sample DWG would be nice with explanation of your goal...
M.R. on Youtube
« Reply #2 on: May 08, 2018, 06:05:44 PM »
I don't think so. Some post processing would be required.
VovKa
  • Ukraine
« Reply #3 on: May 08, 2018, 06:46:47 PM »
(ssget "_X" (list (cons 0 "TEXT") (cons 1 "##")));2 digits
(ssget "_X" (list (cons 0 "TEXT") (cons 1 "###")));3 digits
(ssget "_X" (list (cons 0 "TEXT") (cons 1 "##,###")));2 or 3 digits
« Reply #4 on: May 08, 2018, 07:06:06 PM »
(ssget "_X" '((0 . "TEXT") (1 . "~*[~0-9]*"))) ; only digits
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #5 on: May 08, 2018, 07:45:18 PM »
If you want control over your selections (ie only filter selected, not ALL ):
I'd try either
  1. (ssget  '((0 . "TEXT") (1 . "~*[~0-9] *")))
  2. (ssget  "+.:S" '((0 . "TEXT") (1 . "~*[~0-9] *")))
  3.
or for Text OR MText
  1. (ssget  '((0 . "*TEXT") (1 . "~*[~0-9] *")))
  2. (ssget  "+.:S" '((0 . "*TEXT") (1 . "~*[~0-9] *")))
  3.
Called Kerry in my other life
I live at UTC + 13.00
« Reply #6 on: May 08, 2018, 08:20:06 PM »
Don't we need to include negative integers?
The Op did not include them in his examples but.
kdub_nz
  • SuperMod
« Reply #7 on: May 08, 2018, 08:46:21 PM »
Hi CAB
I just realised that my code is incorrect ... it allows in characters.
Coder
« Reply #8 on: May 09, 2018, 02:37:10 AM »
Thank you guys for your kind replies, that was very helpful.
