Author Topic: Substituting [simplex.shx] for [romand.shx]  (Read 2760 times)
amc.dicsac
  • Autocad 2008
« on: May 04, 2018, 12:28:55 PM »
Yesterday I was changing some files and suddenly I realized that all my texts that were in Romand style were changed to Simplex.shx, I closed my file and opened another one but it happened to me the same try to do everything possible but not I find the solution I hope someone can help me.
Thank you
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
Crank
Re: Substituting [simplex.shx] for [romand.shx]
« Reply #1 on: May 04, 2018, 01:06:43 PM »
If Romand.shx isn't in your search paths, the the font of the variable FONTALT will be used. I think in your case this variable point to simplex.shx.
Simplex.shx is also located in your support search path, so this font will be available.
Check in OPTIONS if
X:\\program files\\autodesk\\autocad 2018\\fonts\\ is included. Restart your drawing and everything should be back to normal.
